Strange Basement Walls - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Gary in WA
  • 1 Post By Str8AheadInc
Old 03-26-2017, 05:36 PM   #1
Strange basement walls
So I am getting started with remodeling my basement and have always wondered why in the basement under the front and rear outside step there are bump outs? It is a 1950's rambler in the Midwest. If any one has any clue what it was used for or what they are using it for currently in a finished basement post away! Pic for details
Cpflip is offline   Reply With Quote
Old 03-26-2017, 05:46 PM   #2
Rewards Points: 6,140
Re: Strange basement walls
I believe what you are referring to as a bump out is just the foundation going out, across, and back in to provide solid support for the steps or landing area. As long as they are not a water problem they are great as they also strengthen the wall.
As for use, that would fall back on your imagination or as you asked suggestions here.
What is your climate region?
Is the foundation dry?
How do you want to finish the inside?
One of those hidden doors where you can hide your safe.
Bud
Bud9051 is offline   Reply With Quote
Old 03-26-2017, 06:06 PM   #3
Very cold climate ND weather! But I do like the hidden room idea for a safe I've seen cool hinges for bookshelfs to become a door. Thanks for the advice!
Old 03-26-2017, 06:49 PM   #4
Property Mgt/Maint
Rewards Points: 6,546
In 1950, possibly coal storage
Yodaman is online now   Reply With Quote
Old 03-26-2017, 07:01 PM   #5
Registered User
Rewards Points: 526
------------------------------Welcome to the forums!---------------------------
Be sure to add some air movement in that cubby against mold... ask your local AHJ about the bump-out, probably more familiar with the local practices than I am from here. Do you have higher headroom than the 7' as pictured? Might want to ask locally what is required to finish the basement with a quick call/internet requirements.
Here are your energy requirements per Code, Table on pp. 9/13; https://www.energycodes.gov/sites/de...ectiveness.pdf
Gary
Nealtw likes this.
Old 03-26-2017, 07:26 PM   #6
Rigid insulation on the walls and maybe a tiny source of heat, or air flow to be sure there is no condensation. We inherited a bunch of cut crystal and asked our insurance co if it would be covered and NO, needed an appraisal and a rider and the cost was outrageous. Much easier to secure it within the home than to pay the insurance. Since gone in case anyone who shouldn't be reading is reading.
Bud
Old 04-02-2017, 08:14 PM   #7
Professional
Rewards Points: 188
Coal bunker! We have a lot of those in Fairbanks where 40 to 50 below is not uncommon.
Yodaman likes this.
Str8AheadInc is offline   Reply With Quote
Old 04-13-2017, 11:06 AM   #8
Rewards Points: 4
Coal Rooms are a chore to clean up but it looks like you are past that point.
WilsonInspected is offline   Reply With Quote
Old 08-02-2017, 02:21 PM   #9
Rewards Points: 32
looks strange. good luck
Dennis Brown is offline   Reply With Quote
Old 08-02-2017, 03:05 PM   #10
Rewards Points: 1,042
Bud has it right, foundation for porch landing.
Canarywood1 is offline   Reply With Quote
Old 08-02-2017, 03:12 PM   #11
retired framer
Rewards Points: 20,618
We don't often see porches with a good foundation that lasts 70 years.
Quality build.
Old 08-02-2017, 05:51 PM   #12
I had a door on mine, used it for storing summers bounty of canning.
Old 09-02-2017, 04:57 PM   #13
Rewards Points: 4
Added support and storage. I take all the extra space I can get
AaronAPR is offline   Reply With Quote
Old 09-02-2017, 06:42 PM   #14
Rewards Points: 1,251
That's where the previous owner put the bodies
KHouse75 is offline   Reply With Quote
Moisture/condensation on interior basement walls christopher66 Concrete, Stone & Masonry 6 03-11-2017 05:37 AM
Mold/wetting on basement walls, condensation? sm47 Building & Construction 12 01-19-2017 03:18 PM
Insulate rim joist & basement walls- if exterior walls have no insulation? cbrc5eric Insulation 5 02-01-2012 07:47 AM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
