Stove Next To Pantry Cabinet Protection - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By firehawkmph
Old 03-27-2017, 08:42 PM   #1
Rewards Points: 6
Stove next to Pantry Cabinet Protection
Hi Everyone,
I recently moved into a home where there is a stove that sits next to a pantry cabinet. The cabinet is countertop depth and goes floor to ceiling. There is probably an inch between the stove and the cabinet. It does not appear to have any damage to the wood, but it is splattered with grease and very sticky.
I plan on redoing the kitchen but wont have funds available for 3-5 years. What is the best thing for me to do temporarily after I clean this wood. I was thinking of installing 1/4 durock and then putting decorative stainless steel of some sort over the top. This way its easier to clean and the durock can provide some protection from the stovetop flames.
Other than tearing the entire cabinet out, what are my options. Thanks
Mods, not sure if this should of been under appliances, kitchen/bath or here. Sorry if I chose the wrong area.
petes67bird is offline   Reply With Quote
Old 03-27-2017, 09:38 PM   #2
firehawkmph's Avatar
Rewards Points: 2,444
Re: Stove next to Pantry Cabinet Protection
I wouldn't worry about the durock, if it hasn't burned up already it probably won't. Nice piece of stainless steel would be nice and not hardly noticeable from the front. Whoever laid the kitchen out made a boo boo.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
petes67bird (03-27-2017)
Old 03-27-2017, 09:41 PM   #3
Rewards Points: 6
Mike Hawkins
Thanks. What about adding a sheet of stainless directly to the wood, would that be help? Do you think I would be safe even putting those tin fasades on the side they sell at home depot, it says heat resistant to 140 degrees. Thanks again
Old 03-27-2017, 09:42 PM   #4
Rewards Points: 6
here is the tin http://www.homedepot.com/p/Fasade-24...0-27/202025362
here is the stainless http://www.homedepot.com/p/Frigo-Des...30SS/100664604
Old 03-28-2017, 06:15 AM   #5
I think I would go with the stainless steel. It's thicker, would be easier to clean, and would also stand up to any heat better. They list a 30" x 24" piece. You could use that. It says they come predrilled in the corners, so mounting would be very simple.
Mike Hawkins
Dave Sal likes this.
Painting grooves in kitchen cabinet doors. jcraw84263 Painting 5 11-10-2011 12:05 PM
Wall oven too Wide for Cabinet victor07 Carpentry 8 01-02-2011 11:09 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 09:28 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 09:30 PM
How to get low voltage through a corner pantry for cabinet lighting? ClemsonJeeper Electrical 7 11-11-2009 09:44 PM
