Steel Beam To Top Plate Connection - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-27-2013, 01:09 PM   #1
Steel beam to top plate connection
I am trying to figure out what size bolts to use to secure a 13' W8X10 drop beam to a 2x4 top and bottom plate. The spacing would be 16" OC. Also, the beam will be supported by two 2-2X4 studs on each end, and flush against foundation walls. Will the beam need to be secured to the foundations walls as well? If, so what kind of end plate should I use?
Thanks for any help,
Shaughn
floridashaughn is offline   Reply With Quote
Old 10-27-2013, 07:16 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
typcially 1/2" diameter bolts for fastening the plate to the beam, and 1/2" threaded thats set into the foundation with 2 part epoxy or 1/2" diameter concrete wedge anchors
woodworkbykirk is offline   Reply With Quote
Old 10-29-2013, 12:59 PM   #3
Rewards Points: 35
Shaughn
I'm trying to envision what you are describing.
Are you trying to fasten a 2X4 to the top flange of the beam and another one to the bottom flange?
Is this permanent? What is the purpose of the beam?
d189379 is offline   Reply With Quote
Old 10-29-2013, 01:52 PM   #4
Connecting the top flange to the 2x4 roof joist plate, then a 2x4 to the bottom flange for drywall. The beam is replacing an interior load bearing wall. Is it normal practice to support a steel beam with a 4x4 column or 2-2x4 studs.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 12:08 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 06:14 AM
