Steal Space From Adjoining Bedroom For Closet Space In Master Bedroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-16-2016, 01:08 PM   #1
Rewards Points: 4
Steal space from adjoining bedroom for closet space in master bedroom
Hi everyone,
We have a 70s ranch style home that has small closets. It is a 4 bedroom home of about 2200 sf. Adjoining the master bedroom is another bedroom currently being used as an office. The smaller bedroom is 11x11'. In between the two rooms are closets that are about 2.5' deep in each room by about 13' in length. My question is, does it make sense to steal about 3' from the bedroom/office space to enlarge the size of the closet, primarily for the master bedroom? The remaining space in the smaller room would be about 8x11' and could still be used for an office or small bedroom. Has anyone done something similar? What are your thoughts? Thank you!
jaspenn is offline   Reply With Quote
Old 12-16-2016, 02:07 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,064
Re: Steal space from adjoining bedroom for closet space in master bedroom
As long as it works for you and it is structurally possible, why not.
Keep in mind that placement of walls can sometimes be a result of structural requirements and you may not be able to just move a wall at a whim without some more work.
Old 12-16-2016, 02:36 PM   #3
If you remove the closet in the smaller room in the process, you will no longer be able to say you have a four bedroom house, as a closet is required for a room to be called such in most locations.
Your call, just pointing out details.
stick\shift is offline   Reply With Quote
Old 12-16-2016, 03:15 PM   #4
Rewards Points: 4
Thank you for the observations. Yes, I'm aware of potential structural issues. In reality, we would be moving an existing wall about 3 feet. I could retain some of the closet space for the smaller room and maintain it has a bedroom. Ideal for munchkins!
Old 12-18-2016, 09:19 AM   #5
Rewards Points: 2,388
If you don't need the room, open a walk way and use it as walk in closet. If sell the house, just close the opening and call it a bedroom. I don't think there is a need to make permanent changes.
carpdad is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Cold Master Bedroom BeMurda HVAC 6 12-05-2011 05:36 AM
Master bedroom and bath remodel toocheaptohire Kitchen & Bath Remodeling 1 03-06-2011 08:22 PM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
Master bedroom placement near dining/living room EdieKay Remodeling 0 04-11-2010 06:48 PM
