Staircase/Wall - What Can I Remove? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-03-2014, 12:05 PM   #1
Rewards Points: 14
Ok, sorry for cell phone pictures that are terrible quality, portrait, and big.
The plan is to remove everything, all the framing, etc. so I can seal my slab floor. Then I want to put a closet back in and convert the under stair space into bookshelves.
This is the staircase and wall in question. The wall is just 1/4" paneling. Nothing special. To the left of it is the door in the below picture.
This is all a small closet under my steps that I'm having to remove to re-finish my basement.
Here's how it's all set up.
The green square up top are the floor joists. These are sitting on a steel poll which is inside the yellow box in between the 2x4s. The joists do not sit on top of anything in the red square. There is a gap there. The white area on the left is the side of the steps running from the floor to the joists.
Then there are these 2x4s that are mitered and connect to the steps. These are what I'm most unsure of. I don't think they are there for load bearing, I think they are just there to give the plywood on the other side something to nail into.
Does all this make any sense?
minker17 is offline   Reply With Quote
Old 07-03-2014, 12:12 PM   #2
Retired Moderator
Rewards Points: 7,174
The stairs are attached to the floor joists---and are self supporting down to the slab--all of that 2x4 wall structure was added after the house was built.
As long as there is not a structural column holding up the floor joists--you will be safe removing all of that----
Old 07-03-2014, 12:15 PM   #3
Rewards Points: 14
Cool, that's what I thought. The house is 55 years old and I know the basement was finished well after the house was built.
Thanks!
The Following User Says Thank You to minker17 For This Useful Post:
oh'mike (07-03-2014)
Old 07-03-2014, 12:36 PM   #4
Retired Moderator
Get out the Saws All---time to get a new tool!
Old 07-03-2014, 04:31 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,496
Are the stringers continuous from top of stairs to the bottom? It is hard to tell from the pictures.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 01:26 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 09:09 PM
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 09:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 10:45 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 02:10 AM
