Sound Deadening Drywall Vs MDF - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 4 Post By chandler48
  • 1 Post By ChuckF.
Old 08-12-2017, 06:54 PM   #1
Rewards Points: 20
Sound deadening drywall vs MDF
I'm replacing paneling in my living room and as part of the remodel we are installing a 65-75' TV on the finished wall. The problem is, the only wall that will accommodate that size TV separates the master bedroom from the living room. So, terms of soundproofing, would MDF be better Than 1/2 or 5/8 drywall?
Rick63 is offline   Reply With Quote
Old 08-12-2017, 07:25 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,612
Re: Sound deadening drywall vs MDF
About the only thing you can do to deter sound movement between walls is to uncouple the walls, but that isn't always easy to do. I would install Roxul Safe 'n Sound insulation between the stud bays to help as best as it can. Sound travels through hard connections, ie. sheetrock attached solidly to studs with sheetrock on the other side.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Rick63 (08-12-2017)
Old 08-13-2017, 06:00 PM   #3
Rewards Points: 17,890
Going to have to crack some eggs if you want to make an omelette.
Whole lot of extra work to do this right.
All the sheetrock needs to go.
http://www.soundproofingcompany.com/...roofing-walls/
Old 08-13-2017, 07:10 PM   #4
Rewards Points: 1,066
Seal the outlets and switch boxes and put another layer of sheetrock on using a whole lot of the green glue goop.
It won't be silent, but it will cut down on the sound transmission.
NotyeruncleBob is offline   Reply With Quote
Old 08-24-2017, 05:30 PM   #5
Rewards Points: 18
The previous suggestions are excellent ideas, if you can add thickness to the wall and it's in your budget, sound deadening sheathing panels (they are a 'low density fiberboard' available at Home Depot and probably other places) behind MDF is another option. The sound-deadening insulation in the wall will help, too.
If your budget and/or space is limited, as a minimum, I suggest a bead of roofing mastic on the studs as a cushion before attaching a layer of MDF and then adding a sound-deadening insulation between the studs.
HotRodx10 is offline   Reply With Quote
Old 08-29-2017, 09:57 PM   #6
Rewards Points: 12
Just go the lead wall route like they do for radiology departments. That way you can do x-rays with it too! Haha just kidding.
Insulation would definitely help and the ideas above would help a ton. That's a tough one just because it's the immediate wall to the bedroom.
colohandyman is offline   Reply With Quote
Old 09-23-2017, 07:00 PM   #7
Rewards Points: 150
Sounds like for what you're doing / needed I'd install Roxul Safe 'n Sound insulation and be done with it.
http://www.soundproofingcompany.com/...rstanding-stc/
Kemper100 is offline   Reply With Quote
Old 09-23-2017, 11:23 PM   #8
Rewards Points: 1,744
Another way to go is simply to remove the sound from that wall by using a bluetooth or wired remote speaker system. The speakers that come with TV's these days are pretty lousy anyway.
chandler48 likes this.
ChuckF. is offline   Reply With Quote
double glazed window dennishcoook Windows and Doors 6 02-13-2016 09:04 PM
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 08:42 AM
How to repair a doorknob hole in drywall Sir MixAlot How To Guides 5 01-27-2015 07:17 AM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
Sound dampening advice needed steel1 General DIY Discussions 10 10-22-2008 01:51 AM
