Something To Ponder For DIY'ers - Remodeling - DIY Chatroom Home Improvement Forum
Unread 06-05-2019, 06:20 PM   #1
Rewards Points: 1,578
Something to ponder for DIY'ers
When, as a DIY'er, not as a professional, do you feel it necessary to pull a permit?
When you run a new electric circuit?
Or a new sub-panel?
Do something that you haven't done before and just want it checked?
How about if you replace all your faucets?
Replace a toilet?
Turn a Tub/Shower into a full shower?
Add a complete bathroom in the basement?
Or,
Replace an Exterior Door or Window with one the similar size?
Knock down a non-load bearing wall?
Replace an exterior window or door with a larger one?
Move an exterior door or window to a new location?
How about if you convert your basement to a livable area by adding 2 bedrooms, and a bathroom?
The only stupid question is the one you DON'T ask!
Most of all, have fun! It ticks people off and ruins their day.
ktownskier is online now   Reply With Quote
Unread 06-05-2019, 07:02 PM   #2
I see permits as extra protection for less than what I save to hire a pro. As a realtor it also helps to show that something like an extra bedroom or bathroom is "up to code". Certain things like a single circuit or toilet replacement, come on nobody cares and it wouldn't be worth it. A major Reno, subpanel, or messing with water supply lines I would definitely get it done. Exterior work is 50/50 for me.
Mhays02 is offline   Reply With Quote
Unread 07-03-2019, 01:51 PM   #3
Rewards Points: 6
Re: Something to ponder for DIY'ers
I think for small jobs (replacing faucets, window replacement, doors, etc) pulling a permit is overkill. For anything where you are going to have to mess with the "bones" of the house (load-bearing walls, adding a whole new bathroom, mess with electrical or plumbing) pulling a permit is almost a necessity.
I just did a complete bathroom remodel in St. George and pulled a permit just to be safe.
And you should probably check and see what your city requires.
Good luck!
StGRemodeling is offline   Reply With Quote
