So I Would Like To Convert This Space Into A Place To My My Pets. - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-12-2014, 02:13 PM   #16
Originally Posted by Bud Cline View Post
I'll be darned! WHO KNEW?
So can one buy "Bunny Litter"?
So I would like to convert this space into a place to my my pets.-rabbit-litter-box.jpg
It's pretty much in the small animals section in every single petstore everywhere. It's as available at Cat Litter.
babiebun is offline   Reply With Quote
Old 06-12-2014, 02:19 PM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Originally Posted by babiebun View Post
Attachment 85943
Had no idea all of that was going on with bunnies. I'm getting an education. I buy cat litter but have never seen bunny litter, at least never paid any attention to it anyway.
XXX
Old 06-12-2014, 02:33 PM   #18
JUSTA MEMBER
Rewards Points: 3,494
Bunny litter?
I thought people used Hamster litter.
ED
de-nagorg is offline   Reply With Quote
Old 06-13-2014, 02:31 AM   #19
Well, rabbits do use hamster litter. (The paper-based ones though.) Rabbits can also use some types of cat litter.
Anyway, I have to make a final decision.
Would the shed or the small attic space be more cost-efficient? In terms of initial building costs (adding the needed insulation, flooring, etc to make them habitable for rabbits) and long term costs (such as electricity, and other bills.).
Thank you so much guys!
Old 06-13-2014, 09:54 AM   #20
PoleCat's Avatar
Rewards Points: 1,652
Inside will be much cheaper.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-13-2014, 11:38 AM   #21
JUSTA MEMBER
I had another thought that you need to consider.
If this attic space is on the southern exposure it needs to be better insulated than normal, because the afternoon sun on a southerly facing roof is terribly hot.
And your little bunnies naturally burrow underground for a reason other than protection from predators.
And I wish you good luck with this project.
ED
Old 06-14-2014, 09:41 AM   #22
Rewards Points: 2,432
As said already, cheap vinyl floor. Cover entire area with 1 1/2" foam board (just tack them) and seal with spray foam. Save original door, replace with cheap door and cut out most of it. Staple front with insect screen and maybe inside with mesh pre-filter for air filters and door bottom with brush weather strip (mom will be happier).
Any ac will freeze in that space and probably too cold for animals, though my kids guinea pigs seem to be fine with central air temps.
carpdad is offline   Reply With Quote
Old 06-18-2014, 07:04 AM   #23
Rewards Points: 79
Originally Posted by de-nagorg View Post
Bunny litter?
ED
I thought people used toilets!
eclark is offline   Reply With Quote
Old 06-18-2014, 09:12 AM   #24
JUSTA MEMBER
OH a wise guy huh.
NYUK NYUK
Old 06-18-2014, 09:12 AM   #25
PoleCat's Avatar
Some of us are rebels.
Old Septic pipe flooding into crawl space ktipton Plumbing 2 04-14-2011 02:18 PM
Crawl Space Advice mjarema414 Building & Construction 0 02-04-2011 08:09 AM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
How to attach this garage and convert it into a living space? BleachCola Building & Construction 16 02-02-2008 03:40 PM
Crawl Space - to vent or not? tomandlu Building & Construction 2 01-15-2008 07:23 PM
