Sistering Studs - Which Nails? - Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 05-18-2019, 01:02 PM   #31
Rewards Points: 1,290
Re: Sistering studs - which nails?
Sure looks like your bottom plate is gone
MTN REMODEL LLC likes this.
Anti-wingnut is offline   Reply With Quote
Old 05-18-2019, 01:11 PM   #32
HenryMac's Avatar
Rewards Points: 998
Guys you're steering this fella in the wrong direction.
You can't use deck screws for framing, they aren't for structural use.
Any good inspector will make you remove them. You must use structural fasteners.
HenryMac is offline   Reply With Quote
The Following User Says Thank You to HenryMac For This Useful Post:
jbrah (05-22-2019)
Old 05-19-2019, 07:26 AM   #33
Rewards Points: 6,881
Where either the drywall or siding is still attached to the damaged stud I would not use nails at all.
I would use 3" square drive construction screws to minimize any collateral damage.
MTN REMODEL LLC and Nealtw like this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
jbrah (06-02-2019)
Old 05-19-2019, 09:07 AM   #34
Rewards Points: 26
Originally Posted by jbrah View Post
Here's what I'm working with.
You've got to cut out that rotted wood. It's a little tough from here to tell you exactly how to do it. Don't know if there's a floor above you, if that's a gable end etc?. You can cut out the bad part, splice in a new piece and sister full studs to repair. You can use a construction adhesive to glue the sheathing to the new studs.
Sent from my SM-J320V using Tapatalk
woodyg2060 is offline   Reply With Quote
The Following User Says Thank You to woodyg2060 For This Useful Post:
jbrah (05-22-2019)
Old 05-22-2019, 11:16 AM   #35
Rewards Points: 484
Also possible to use structural screws like the ones from Simpson Strong-Tie or to thru bolt the sister to the original stud. Nails are cheaper but if access is a problem then the more expensive fasteners will cost under $20.
Calson is offline   Reply With Quote
The Following User Says Thank You to Calson For This Useful Post:
jbrah (06-02-2019)
Old 05-22-2019, 11:51 AM   #36
Rewards Points: 180
Because the nails will push the damaged stud and potentially enlarge the holes used by existing fasteners securing the siding to the damaged studs?
So something like this: https://www.homedepot.com/p/Grip-Rit...GCS1/204959258
except in square drive - I guess square drive is easier to drive without camming out?
No need to pre-drill with construction screws?
jbrah is offline   Reply With Quote
Old 05-22-2019, 12:15 PM   #37
Yes or otherwise damage the siding.
Exactly like that but I buy them from a bulk box at a real harware store for 5.99 per pound.
Square drive is 10 time less strippable than Phillips.
Sometimes in old hardened wood I predrill the old wood. Not need for it in new wood.
Colbyt
jbrah (05-22-2019)
Me ranting about nails... Pittsville Building & Construction 16 12-27-2018 04:08 PM
spliced studs on balloon frame wall jb8578 Building & Construction 4 06-01-2017 12:59 AM
Siding right on studs? Davef_dci Carpentry 6 03-07-2013 05:31 PM
The stringer on my stairs is pulling away from the wall/ studs. georgiabiker Carpentry 10 01-24-2013 03:53 PM
Sistering or shimming wall studs for drywall? GSilversVeneer Carpentry 1 11-28-2010 12:41 AM
