Sistering Studs - Which Nails? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 05-17-2019, 06:38 PM   #16
Rewards Points: 1,290
Re: Sistering studs - which nails?
Okay then, 3 1/2 x .161 nails since that’s what is on the plans.
Anti-wingnut is offline   Reply With Quote
Old 05-17-2019, 07:00 PM   #17
retired framer
Rewards Points: 18,670
Originally Posted by Anti-wingnut View Post
Okay then, 3 1/2 x .161 nails since thatís what is on the plans.
See that does not make sense so me, we changed to 3" when they started dimensioning lumber to 1 1/2" thick
Do not use flat bottom gables with scissor trusses.
Old 05-17-2019, 07:01 PM   #18
HenryMac's Avatar
Rewards Points: 998
Originally Posted by Nealtw View Post
3" common nails but the treated lumber should get galvanized, you could get away with 3" deck screws and you would us the same to attach to the old stud in 3 or 4 places.
Never use deck screws for structural applications such as what you are discussing.
Nealtw keeps telling folks to use deck screws... even though we've been over this numerous times.
See post #8 here: https://www.diychatroom.com/f19/what...ew-use-654649/
HenryMac is offline   Reply With Quote
The Following User Says Thank You to HenryMac For This Useful Post:
jbrah (05-22-2019)
Old 05-17-2019, 07:08 PM   #19
retired framer
Si if he was using screws because some are in a place hard to get to and he would be screwing into treated lumber you would say to use?
Old 05-17-2019, 07:40 PM   #20
Rewards Points: 2,464
This is inside and dry treated lumber. Is there still need to use galvanized? I didn't think about it for indoors, although it's been some time since I stopped buying common nails. All I have in stock are 8-10-16 penny galvanized spirals.
OP: if you have a drill, screws are lot easier to use, esp for few pieces. Also if you predrill. Drill just the toe holes and not the plates for best bite. Nails are for budget reason. Also toe nailing overhead is no fun esp if the nail bends half way in. Lumbers can be predrilled after cutting but before the install.
Nealtw likes this.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
jbrah (05-22-2019)
Old 05-17-2019, 08:07 PM   #21
Usually Confused
lenaitch's Avatar
Rewards Points: 2,028
You know better than that. Common is the diameter and length is penny (d). For sistering one should use 16d gunners, 10d commons or 16d sinkers.
https://www.constructioncanada.net/f...-construction/
https://abag.ca.gov/bayarea/eqmaps/fixit/ch3/sld057.htm[
It's not a measurement/classification system used up here. Then again, as a DIYer, I've never heard of gunners or sinkers either.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 05-17-2019, 08:09 PM   #22
HenryMac's Avatar
Rewards Points: 998
A structural screw that is coated for use in pressure treated wood. GRK makes them.
jbrah (05-22-2019)
Old 05-17-2019, 08:31 PM   #23
retired framer
So a 3"deck screw?
Old 05-17-2019, 09:08 PM   #24
Rewards Points: 180
What kind of screw would you use? My understanding is deck screws shear much easier than nails.
jbrah is offline   Reply With Quote
Old 05-17-2019, 09:11 PM   #25
retired framer
That is right, exactly what shear are we worried about.
MTN REMODEL LLC likes this.
Old 05-18-2019, 05:25 AM   #26
For putting 2 lumbers together you don't have any shear concerns. Shear is also when we are talking about the whole wall, or specific engineered local area such as a shear wall. But engineers would never specify nails or screws, it would step up to bolts. Even headers can be assembled with thinner pneumatic nails, just more used.
My anecdotal reason would be that I broke off plenty of short drywall screws but never the deck screws. I've even used 3-4" screws that look like drywall screws. As long as you're thinking about the shear, if using screws, use 3 where 2 common nails would work. If you trust nails, predrill the stud.
BTW, is the damage where the nails are? If not, you can face nail the sister and not worry about anchoring the new to old plates.
Again, shearing shown in lab conditions with a single screw or nail is valid but not really in real construction scales. In real situations, shear comes from forces that can move entire structure, not just a few studs.
Nealtw likes this.
Old 05-18-2019, 12:40 PM   #27
Rewards Points: 180
Here's what I'm working with.
Old 05-18-2019, 12:51 PM   #28
retired framer
Do the ceiling joists land on this wall, you will want a temp wall for those.
You make be into floor trouble too if the floor is wood. if you cut the studs beside the window replace them with blocks under the cuts as well as the sister.
Take out as much crap as you can, any thing a little questionable that you have to leave in place, paint that with a copper treatment like for treated lumber. That is what our engineers call for, to deal with anything living in there.
Old 05-18-2019, 12:55 PM   #29
I think your scope of work is a lot bigger than you think
Old 05-18-2019, 12:59 PM   #30
Rewards Points: 180
Yes.
No, it's just tile adhered to concrete.
Nealtw likes this.
Me ranting about nails... Pittsville Building & Construction 16 12-27-2018 04:08 PM
spliced studs on balloon frame wall jb8578 Building & Construction 4 06-01-2017 12:59 AM
Siding right on studs? Davef_dci Carpentry 6 03-07-2013 05:31 PM
The stringer on my stairs is pulling away from the wall/ studs. georgiabiker Carpentry 10 01-24-2013 03:53 PM
Sistering or shimming wall studs for drywall? GSilversVeneer Carpentry 1 11-28-2010 12:41 AM
