Shower Tile Queston - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-08-2015, 04:58 PM   #1
Rewards Points: 396
Shower tile queston
I have an accent tile area in my shower with a decorative travertine trim surrounding it. The trim sticks out about a half inch from the surrounding tile and I noticed after taking a shower there are some areas on the top of the trim that have some standing water. Any issues with that?
detroittigerfan is offline   Reply With Quote
Old 04-08-2015, 08:16 PM   #2
Rewards Points: 17,890
There will be at some time.
Never should have used tile that much thicker.
Old 04-08-2015, 10:00 PM   #3
Rewards Points: 996
what is under the tile ? lets see a pic.
Fix'n it is offline   Reply With Quote
Old 04-08-2015, 11:05 PM   #4
Rewards Points: 750
is the trim waterproof? is there any cracks/leaks? is there any way to silicone said cracks/leaks?
Hick is offline   Reply With Quote
Old 04-09-2015, 03:21 PM   #5
Rewards Points: 396
I have kerdi underneath. The water is still sitting there the whole day though.
Old 04-09-2015, 03:23 PM   #6
Rewards Points: 396
What do you suggest? The trim is like a chair rail design. Should I of slopped the top?
Old 04-09-2015, 09:12 PM   #7
Rewards Points: 996
my understanding is that you could fill the shower to the top, and it wouldn't matter. that is, if it was done correctly.
Old 04-22-2015, 06:36 AM   #8
Rewards Points: 370
If you've got a water tight Kerdi shower I doubt it will cause problems. If you can find trim that's the same height but not as thick you could always pop that trim out and replace it. Just spitballin' here.
costgeek is offline   Reply With Quote
Old 04-30-2015, 12:31 AM   #9
Rewards Points: 4,178
What did the installer think was going to happen.?
Don't ever under estimate water.
ron45 is online now   Reply With Quote
Wrong sealer for shower tile. bcdemon Concrete, Stone & Masonry 0 08-29-2012 07:50 AM
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 11:29 AM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 02:32 PM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
