Shower Tile Question - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joeg679
Old 10-13-2017, 11:49 PM   #1
Rewards Points: 270
Shower tile question
I am redoing a shower and I used Kerdi board around the 3 walls and hardiboard on the ceiling because it was cheaper and water won't really hit there. When you adhere tile to kerdi board, the thinset has to be unmodified. I have half a bag of modified leftover from the Ditra in the rest of the bathroom. D
o I have to use the modified for the ceiling tiles to hardiboard or can I use the unmodified to do the ceiling, cover the screws and then do the tile over the kerdi? The reason why I don't want to use the modified is because it's grey and the tiles are white glass. I'd rather use the white unmodified. If I have to, I'll get a bag of white modified for the ceiling. Thanks for your help.
joeg679 is offline   Reply With Quote
Old 10-14-2017, 07:00 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,242
Re: Shower tile question
Depending on how old the bag of thinset is, you should just trash it.
It does go bad after time.
Old 10-14-2017, 07:51 AM   #3
Rewards Points: 898
I don't think kerdi board on the walls requires unmodified, you're thinking of Ditra that goes on the floor. Use grey TS on white tiles, that way when you grout the missed thinset will be easy to spot and can be scraped out and touched up with grout. If you use a matching color TS it's harder to spot.
BIG Johnson is offline   Reply With Quote
Old 10-14-2017, 10:17 AM   #4
Rewards Points: 118
Schluter does call for either unmodified thinset mortar, or their proprietary All-Set or Fast-Set mortars. See here.
That said, I thought that many glass tiles manufacturers called for modified thinset. I have no experience with glass tile, so I'm not really sure what to advise. Does the tile manufacturer have any install specifications?
LanterDan is offline   Reply With Quote
The Following User Says Thank You to LanterDan For This Useful Post:
joeg679 (10-14-2017)
Old 10-14-2017, 11:39 AM   #5
Rewards Points: 898
I missed that it was glass, in that case he needs white.
The Following User Says Thank You to BIG Johnson For This Useful Post:
Old 10-14-2017, 12:20 PM   #6
Rewards Points: 270
Thanks for the replies. They are glass tiles and for the Ditra, on the floor, I used modified thinset. The Kerdi calls for unmodified to set tile in, but glass tile requires modified, so it looks like I'll have to use modified.
Old 10-14-2017, 12:51 PM   #7
Rewards Points: 270
UPDATE: I just called Schluter and the guy told me that the use of modified thinset over Kerdi board is ok and will not effect the waterproofing properties. The only thing it will do is increase the curing time of the thinset. He said that he's seen instances where it takes a week to cure. So, if the only downside is curing time, then I'm ok with that. Thanks for your help guys.
Jaime296 likes this.
Tile over tile in a shower area brucem609 Flooring 0 03-17-2014 07:09 PM
URGENT!need to find the order of putting in a tile shower gailquiler3 Plumbing 6 11-19-2012 08:10 AM
beginner's question about shower fixtures diy'er on LI Plumbing 6 02-19-2012 10:05 PM
Installation of Granite Tile On Shower Walls Spacing Question. taras1 Building & Construction 2 08-04-2010 11:48 AM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
