Shower Pipe Waterproofing - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-23-2018, 07:25 AM   #1
Rewards Points: 26
Shower pipe waterproofing
I am remodeling our bath and am in the process of waterproofing.
I am installing a shower panel that is pre plumbed meaning all I have coming out of the wall is hot and cold pex pipe. these simply thread onto the supply lines in the panel.
Question is: what is my best option to water proof these as they are not exactly firmly in place.
I am aware of the Kerdi pipe seal, but I have used a roll on membrane and will be using a modified thinset for tile and my understanding is that kerdi requires unmodified..
I guess I could use a mesh and more roll on product? but my concern is that when I go to screw on the supply lines it will move and not be a good seal? if I come back with some silicon once hooked up, would that be sufficient? it should not see much water being located behind the panel anyway?
jaigordon87 is offline   Reply With Quote
Shower Head Pipe 325_man Plumbing 14 08-09-2014 06:36 PM
Mysterious Problem with Copper Drain Pipe "Growing" into the Shower imautoparts Plumbing 3 10-16-2012 02:27 PM
Question about PVC drain pipe (shower) nighthawkix Plumbing 1 08-12-2012 07:37 AM
Walk-in Shower, cutting waste pipe kevin327 Plumbing 8 01-25-2012 10:42 AM
shower head pipe snap inside of wall? snosurfa7 Plumbing 3 06-06-2009 09:15 PM
