Shower Head Mounted On Glass Wall? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-11-2017, 07:57 PM   #1
Rewards Points: 2
Shower Head mounted on glass wall?
I am remolding a shower in a small area, 32X48 (shower dimensions). All my existing plumbing is on the solid structural 48" wall. The other walls will be 2 32" glass walls coming from the main structure wall and a full glass swing out shower door in front. So since the shower head will be facing the shower door (so many things wrong about that). Can anyone think it possible to have a hole drilled in the glass so I can plumb it for a shower head spout? I can visualize it, not sure how to have the pipe firm and secure in the glass hole. Any ideas? Am I crazy?
Thank you for your opinions.
Superdave777 is offline   Reply With Quote
Old 04-11-2017, 08:17 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,202
Re: Shower Head mounted on glass wall?
Not if the glass is tempered. If you haven't had the glass made yet, they can specify that panel to be laminated or drill it before tempering, but if you try to drill it now, you are going to get a surprise.
Old 04-11-2017, 08:17 PM   #3
hkstroud's Avatar
Rewards Points: 5,752
Those glass walls or petitions would most assuredly be made of tempered glass.
It is my understanding that while glass can be drilled it must be done before tempering.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 04-11-2017, 08:21 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 686
Put the shower head in the ceiling and use a rain head pattern
Hydronic baseboard mounted to concrete wall Maine1 Remodeling 20 12-26-2012 06:08 AM
Adding a wall mounted seat to a shower Ed911 Kitchen & Bath Remodeling 6 12-14-2012 06:39 PM
Shower valve for rainshower head Liv Plumbing 0 03-29-2012 10:41 AM
is water conservation inside the shower head or the shower hose? vcreation Plumbing 1 11-11-2011 06:20 AM
shower wall stability rtoni Building & Construction 7 01-27-2011 04:11 PM
