Shower Drain Cover - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Fix'n it
Old 08-06-2018, 09:10 PM   #1
Rewards Points: 996
shower drain cover
the shower that i just finished "fixing up" (turned out pretty good, btw), didn't have a drain cover. no biggie, except that i do not see any screw holes to fasten one down. there is a rubber gasket that is somehow fastened down. i did not remove it for fear of damaging something. the hole itself is 2".
any idea what is up with this ?
thanx
Fix'n it is offline   Reply With Quote
Old 08-06-2018, 09:31 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,020
Re: shower drain cover
FIXN..... Ya know we love pictures.....
What drain assembly did you use..... I don't know any that do not provide for a drain "cover"/strainer.
And I don't understand why it is no biggie.... maybe I don't know what a drain cover is.?
MTN REMODEL LLC is offline   Reply With Quote
Old 08-06-2018, 09:41 PM   #3
Rewards Points: 996
i didn't have my camera with me.
i did not install the fiberglass pan, new construction 20ish years ago. basicly what i did : regroute the bottom 4' wall tiles, reset 2 tiles, fix drywall and trim damage, and install a new door.
here is a few pics of before.
Old 08-06-2018, 09:44 PM   #4
Rewards Points: 996
wtf.........
Old 08-12-2018, 09:28 AM   #5
Rewards Points: 996
i found a strainer that just pushes on. idk if it will work yet.
Old 08-13-2018, 08:50 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 748
WOW. what a mess that was. Sounds like you put a band-aid on it though. Save your $$ for a complete re-do soon. If the surfaced was that bad, I can imagine you bad the inner walls are.
Drywall in a shower install? Yikes, not a good plan at all.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 08-13-2018, 10:20 PM   #7
Rewards Points: 996
Jaz
yeah, a bit of a mess, but it only went greenboard deep. cut it all out, just the bad parts. saved the tiles. patched it up and a new door. bandaid, yes, i told her it was. that is all she wanted to pay for. but it does look like new now.
greenboard, blops of mastic on a tile, stick to wall, groute = thats it.
but it did last 20 years, 15 of those with poor care.
Old 08-14-2018, 09:13 PM   #8
Rewards Points: 996
was there today. the straainer i bought doesn't fit
and i pic. that black gasket, it is glued down. supposed to be like that or not, idk.
anyway, here are finished pics.
shower drain cover-img_3100.jpg   shower drain cover-img_3101.jpg   shower drain cover-img_3102.jpg
Old 08-14-2018, 10:38 PM   #9
retired framer
Rewards Points: 18,462
There are 3" snap in strainers , this one has a hair catcher
https://www.danco.com/product/hair-c...over-in-white/
Old 08-15-2018, 08:13 PM   #10
Rewards Points: 996
that hole is 2".
Old 08-24-2018, 12:35 PM   #11
Rewards Points: 996
i found one that fit perfect. kind of fugly. but way better than what was there.
Mike Milam likes this.
Washing maching drain turned shower drain AmyPolzella Plumbing 5 10-13-2017 06:02 PM
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 07:14 PM
Garage Drain Cover matt151617 Plumbing 5 08-09-2011 07:56 PM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 12:49 AM
