Shower Door - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-27-2014, 03:31 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 238
Shower door
On our shower door, the bottom frame does not sit on the tub cleanly. Water gets underneath,and causes a build-up. Is there a certain type of chaulking I can use to seal it and hold it down also??
Barry
Barry J is offline   Reply With Quote
Old 06-27-2014, 04:32 PM   #2
Rewards Points: 17,890
The frame should have been setting in a bed of silicone.
There is no way to attach the frame to the tub it's self.
Old 06-27-2014, 05:00 PM   #3
DIY Homeowner
Barry J's Avatar
Rewards Points: 238
It is, but with it moving, when you press down on it, it doesn't seal well
Old 06-27-2014, 06:41 PM   #4
If someone cut it to long it's going to bow.
Old 06-27-2014, 07:03 PM   #5
Retired Moderator
Rewards Points: 7,174
Time for more silicone---cleaning up the crud will be needed---
use a thin knife blade and clean under the loos bottom track---
'then swab with alcohol--
apply clear silicone---
spray quickly with greased lightning--(keep the excess from sticking and smearing to the tub and track)
wipe off excess--
Old 06-27-2014, 08:10 PM   #6
DIY Homeowner
Barry J's Avatar
Rewards Points: 238
Taking off the botton track, right??
Was is greased lightening???
Old 06-27-2014, 08:33 PM   #7
Rewards Points: 582
take doors off ..take header off ..remove side rails...cut old caulking out and lift bottom track, proceed by cleaning old caulking off bottom track and tub surface.....check and make sure bottom track is cut to proper length...if it is apply a bead of silicone on bottom track install on tub and tape it down leave it cure...reinstall other parts caulk were needed ...job finished...
Old 07-02-2014, 03:00 PM   #8
Did any of that advice mention bottom track might be setting on a threshold out of plumb with door or visa versa? Rarely are they perfect but doors are easily adjustable for such) AND... that the threshold (I prefer a solid strip of corian or marble) needs to tilt in... Towards the inside of shower so water doesn't stand on it, but drains in.
tantoes is offline   Reply With Quote
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Shower Door Cleaning Aquin Remodeling 4 04-22-2011 12:34 PM
Shower Door Transom is loose 2031pratt Plumbing 0 12-28-2010 11:26 AM
