Shower Curb Made With Brick - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-15-2014, 08:51 PM   #1
Rewards Points: 576
Shower curb made with Brick
Using brick for the shower curb, can some one answer these 2 simple questions:
1.) what to use to set the brick to cement foundation and each other;
2.) What's the code requirement for the distance/height of the inside top of the finished curb above the drain?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 08-15-2014, 09:04 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Modified thinset.
There is no code requirement relating to showers I am aware of. The height above the drain would depend on how far away the drain was and the degree of slope. The way to do it is to have the top of the finished curb not to exceed six inches above the shower floor as you step out of the shower.
Curious to know why you are using brick.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
digitalplumber (09-02-2014)
Old 08-15-2014, 10:04 PM   #3
Rewards Points: 1,002
I've used masonry mortar.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
Old 08-16-2014, 08:06 AM   #4
Rewards Points: 996
when i did the shower at my condo (i sold it). i used bricks for the curb. doing my research, i found that any wood will fail, sooner or later. but bricks, those don't care if they get wet.
i set them on the concrete floor with thinset. then i did the whole shower with kirdi. turned out fantastic ! the drain was at floor level. the granite curb topper was about 4" off the floor.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 08-16-2014, 08:13 AM   #5
Rewards Points: 996
idk why i never took any more finished pics
Old 09-02-2014, 04:10 PM   #6
Rewards Points: 576
Thanks all, I did not receive emails you guys had answered!
Old 09-02-2014, 04:26 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The Email Notification gizmo was out of service for about two weeks, it's back now.
XXX
Old 09-02-2014, 05:55 PM   #8
Rewards Points: 576
Going to use Kerdi.
Should I use a notched trowel, if yes what size?
Old 09-02-2014, 07:37 PM   #9
Rewards Points: 996
the instructions will tell you what to use and do.
Old 09-02-2014, 08:21 PM   #10
Rewards Points: 576
No I mean for the modified thinset used to secure the bricks, I know kerdi requires 8 x 8
Old 09-02-2014, 08:43 PM   #11
Rewards Points: 996
i just put some down. and got the curb base somewhat flat and level.
i say "somewhat", because mine didn't need to be perfect. as i had a piece of granite cut and i used that as a curb topper. feakin sweet it was.
Old 09-02-2014, 08:45 PM   #12
Rewards Points: 576
That's the plan also. I just need to know how much or how thick?
Old 09-02-2014, 09:35 PM   #13
Rewards Points: 996
i don't remember how much i used. look at it as setting a tile.
also, after the brick was layed, i wrapped it with the kirdi.
digitalplumber (09-07-2014)
Old 09-02-2014, 09:46 PM   #14
Rewards Points: 996
i'm diggin up pics. darn they are hard to find.
Old 09-02-2014, 09:51 PM   #15
Rewards Points: 996
those are pretty flat paver bricks, 2" maybe ?
Shower curb level busyhammer Remodeling 8 08-24-2013 08:12 AM
Shower curb question jayzlookz Remodeling 10 08-20-2013 08:41 AM
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 08:09 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
