Should I Remove Parging Behind Shower Tiles? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-18-2018, 05:56 PM   #1
Should I remove parging behind shower tiles?
I have a layer parging behind my shower tiles that has gotten water damage and has deteriorated in spots. I am planning on installing a direct to stud shower enclosure but there's no studs. Should I remove the parging and add studs or should I try and repair parging and glue/anchor to that?
Should I remove parging behind shower tiles?-20181118_170425_1542585355867.jpg
fdnorthern is offline   Reply With Quote
Old 11-18-2018, 06:08 PM   #2
Rewards Points: 2,840
Re: Should I remove parging behind shower tiles?
Looks like it maybe a gypsum based plaster that was applied 30 / 40 years ago.
If it is Gypsum it should be removed to test it remove some and place it in some Vinegar if it dissolves all but the sand it is Gypsum.
ClarenceBauer is online now   Reply With Quote
The Following User Says Thank You to ClarenceBauer For This Useful Post:
fdnorthern (11-18-2018)
Should I remove Linen Closet to Increase Shower space for resale? amodoko Kitchen & Bath Remodeling 0 06-06-2015 01:11 AM
swap out bath wall tiles: re-tile or remove backerboard NJoytheRide Building & Construction 8 04-16-2011 07:52 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Shower Floor 1 inch Tiles ok to Use? newmex999 Remodeling 9 12-18-2009 04:59 PM
