Shimming Base Cabinets On Concrete - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-23-2016, 10:31 AM   #1
Rewards Points: 81
Shimming Base Cabinets on Concrete
Not sure if this is the right forum or not, but here goes.
Finishing my basement and adding a kitchenette/bar. I have a concrete floor that I plan to tile, but didnt want to put the tile under the base cabinets in case we change it in the future. I plan to shim the base cabinets up about 3/8"-1/2" to keep them in line with the flooring to ease appliance installation.
Does anyone know of any good plastic materials for shimming the base? I could use plywood, but being on concrete I'd prefer if it didnt absorb any moisture. The basement is dry, but just want to be safe.
Maybe plywood with something underneath it like a plastic vapor barrier sheet?
Thanks in advance
BaconK5 is offline   Reply With Quote
Old 03-23-2016, 12:33 PM   #2
Rewards Points: 17,890
Re: Shimming Base Cabinets on Concrete
Vinyl or pressure treated lattice would work, it's sold in strips 8' long.
Old 03-23-2016, 12:53 PM   #3
Rewards Points: 144
http://www.amazon.com/s/?ie=UTF8&key...l_4adojyvekw_e
Many choices out there.Some may seem expensive but will also let you level the cabinet tops for your counters.They mount under the cabinets and should be hidden buy the cabinet sides and toe kick,
mako1 is offline   Reply With Quote
Old 03-23-2016, 04:32 PM   #4
Rewards Points: 270
I just used these in a kitchen remodel - http://www.ez-level.com/. They were fantastic. I had a 12 foot island on a wavy floor. It was rock solid and perfectly lever when I finished.
They keep the cabinet up off the floor, so you won't have concrete to wood contact.
b-boy is offline   Reply With Quote
Old 03-24-2016, 12:38 PM   #5
Rewards Points: 81
Vinyl might work if I can find it in the right thickness, but pressure treated will still absorb and transfer moisture - it just wont rot.
The leveling feet look cool, but theyre spendy and I'm willing to just put in the time to level them with shims. I think I'll just put down some 6mil plastic and then put a strip of plywood down on top of it. That should keep all the wood isolated from the concrete and nice and dry. Then I can use wood shims too.
Old 03-24-2016, 08:42 PM   #6
firehawkmph's Avatar
Rewards Points: 2,456
How would tiling under the cabinets preclude you from changing something in the future? Leaving tile out from under the cabinets will preclude you from changing layouts in the future. When I have a choice, I always tile the whole floor area then set the cabinets.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following 2 Users Say Thank You to firehawkmph For This Useful Post:
jlhaslip (03-26-2016), oh'mike (03-24-2016)
Old 03-25-2016, 09:09 PM   #7
Rewards Points: 2,482
Cheap water proof shims are vinyl flooring, commercial composite flooring, sheet metal rolls, metal plates from lumber hardware, etc. Screw 3-4 cabinets together, level, then shim all the legs through the toe kick space.
carpdad is online now   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Using Concrete as Paver Base? Boiler98 Landscaping & Lawn Care 4 07-27-2012 10:09 AM
Wall Cabinets as Base bjlffire Carpentry 5 01-11-2010 10:34 PM
landscaping backyard with Pavers - needs concrete base? sundar Landscaping & Lawn Care 7 10-09-2008 07:28 PM
