Sealing After Asbestos Removal - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By chandler48
  • 2 Post By mark sr
Old 01-24-2018, 03:09 PM   #1
Rewards Points: 196
Sealing after Asbestos Removal
I'm having an Asbestos abatement crew come in and remove my 9"x9" floor tiles and furring strips in my 1950s built home in basement.
As an extra precaution after removal, before re-finishing, I'm wondering if it's a good idea to put a paint over the walls and floor to seal everythin up. Something like Zinsser WaterTite? Thoughts?
arminius is offline   Reply With Quote
Old 01-24-2018, 04:14 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,570
Re: Sealing after Asbestos Removal
Fill all the holes left by the furring strip removal with either hydraulic cement or concrete patch. No need to allow holes in an otherwise non leaking boat spoil your day.
If the abatement crew did their job, there should be no asbestos left for any problems.
Bondo likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
arminius (01-26-2018)
Old 01-24-2018, 04:15 PM   #3
retired painter
Rewards Points: 1,300
The asbestos abatement crew got rid of the asbestos and cleaned everything up - not sure what there is to gain by a coat of paint other than making it look clean. I'm not fond of paint on basement floors.
Bondo and joecaption like this.
mark sr is online now   Reply With Quote
Tags
asbestos , basement foundation
pulled up the linoleum does it have asbestos? bonniemel Flooring 46 08-07-2016 08:18 AM
Rain seepage stain removal and sealing on bare block walls Peipei9 Concrete, Stone & Masonry 2 03-29-2012 05:37 PM
DIY network and asbestos removal Ranger1227 Building & Construction 5 08-22-2011 03:14 PM
Is this asbestos? enviromom Insulation 7 06-02-2011 02:27 PM
Asbestos Removal Solvent rsilvergun Flooring 2 01-25-2007 12:08 PM
