Rusty Nails In Joist Hanger - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-25-2016, 02:16 PM   #1
Rewards Points: 2
Rusty nails in joist hanger
Well one thing has led to another, as it usually does... I had originally set out to make my basement more soundproof by insulating the ceiling cavity and area above the drop ceiling tiles... Well I noticed my floors are also pretty squeaky which has led me to look at the structural supports. Well the floor joists 16" on center run up attached to a glulam beam. The joist hanger is Stimpson StrongTie. I wasn't able to find the exact same model of hanger on the Stimpson website, I assume its an old model?
I have attached a picture which can describe things much better than I can! As you can see, part of the hanger attaches to the joist with bent metal of the hanger, and the other part of the hanger is nailed into the glulam. The three nails going into the glulam appear to be rusty! Well, this seemed alarming to me. I was wondering if I could use a stimpson screw into the "empty" nail holes in the hangar?? Not really looking forward to shoring up the joists to replace the hangars... ugh. What do you think?
Also, any other suggestions for securing a loud floor FROM BELOW, is helpful.
Thanks!
caitlin622 is offline   Reply With Quote
Old 02-25-2016, 03:06 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,232
Not sure a screw would hold it much better. You would be better putting some joist blocking to tie the floors together, but I am not a framer. There are guys that do this all day long that know this better than me.
I am just not sure a couple of screws would hold that together that much better.
You could also run a 2x4 under the joist to block the bottom.
Old 02-25-2016, 04:31 PM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
all the nail holes in the joist hanger should have nails in them...
WhatRnsdownhill is offline   Reply With Quote
Old 02-25-2016, 04:35 PM   #4
Rewards Points: 17,882
A little surface rust on the heads not going to do any harm and not causing the squecks.
Looks like someone did not use the required real hanger nails that are hot dipped, galv.
Add any missing nails with the right one's.
More likely it's something like undersized sub flooring, no glue on top of the joist, not using T & G, not enough nails used.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Fix'n it (02-25-2016), woodworkbykirk (02-26-2016)
Old 02-25-2016, 11:42 PM   #5
Registered User
Rewards Points: 526
6. Nails and Strong-Drive SD Connector screws may not be combined in a connection.--- from; Simpson
No glue on the T&G joint, air nails or partial, no gap at the header/joist joint, as yours appears...
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 02-26-2016, 10:32 PM   #6
Registered User
Rewards Points: 526
Forgot; hanger too tight on the sides causing noise, no glue under the joist in the hanger, too long a lap at the other end, causing the noise when joist flexes. Redundant to add any lumber under the hanger- may cause more noise... whole reason for the hanger.
Gary
Sloped joist in Simpson non-sloped hanger garya505 Building & Construction 2 07-30-2013 02:22 PM
Joist doesn't match dimension of joist hanger! Stan Shmenge Building & Construction 9 03-15-2011 07:35 PM
33 vs 35 Nails Dilemma banzaitoyota Tools 1 12-28-2010 06:44 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
How to remove old rusty raised deck nails win Carpentry 4 05-18-2009 10:30 AM
