Running Old 12 Guage Hot And Neutral Wire Through A 10" Header - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-11-2014, 03:28 AM   #1
Rewards Points: 2
Question
running old 12 Guage hot and neutral wire through a 10" header
Doing a kitchen remodel and have to install a 10" header with a light underneath. This old house has nob and tube wiring and has one hot and one neutral wire run separately through the top plate into the wall from the attic. Can I put the individual wires through the header sandwich [there is a 1/2" gap through which I can run the wire to the light fixture and then run romex to a switch and outlet] . Or should I be going up into the attic, making a junction box where I would join the old nob and tube hot and neutral to romex or wire in BX cable and pull the BX cable through the header through the header?
HGLtraveling is offline   Reply With Quote
Old 10-11-2014, 09:48 AM   #2
Home Remodeler
Rewards Points: 164
The experts will be here soon. You cannot extend nob and tube.
mikey48 is offline   Reply With Quote
