Round Corner Edges - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-20-2015, 07:41 AM   #1
cia2a's Avatar
Rewards Points: 30
Round corner edges
I have rounded corner edges in a 3 year old house and the seams are coming undone. There appears to be metal corner beads and just applying compound does not work. Any suggestions would be greatly appreciated.
Round corner edges-corner-bead5.jpg   Round corner edges-corner-bead2.jpg   Round corner edges-corner-bead-1.jpg   Round corner edges-corner-bead3.jpg
cia2a is offline   Reply With Quote
Old 01-20-2015, 09:31 AM   #2
Rewards Points: 144
In pictures 1 and 3 the cracking is beyond where the corner bead would terminate.It is mostly in a straight line.I would guess that is a seam there in the drywall that is bad.I don't know why they would have put a joint there but that's what it looks like from the pics.
The last pic looks like it could be a bad joint at a bead.Only fix is to take it out and replace from scratch.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
cia2a (01-20-2015)
Old 01-20-2015, 09:49 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 706
Looks like the corner bead was applied using mud- the paper face kind. For some reason the mud has failed.
IMO- like Mako1 stated, it needs to be pulled and start over.
The Following User Says Thank You to TheEplumber For This Useful Post:
cia2a (01-20-2015)
Old 01-20-2015, 09:53 AM   #4
cia2a's Avatar
Rewards Points: 30
Wow , This is happening all over the house. So I may need to have someone come in and do this. It will not be the original installer.
Thanks to both of you.
Old 01-20-2015, 11:00 PM   #5
Bob Sanders's Avatar
Rewards Points: 2,536
Metal wall studs or wood?
It almost looks like someone framed with extremely wet (wood) studding, and of course now it's dry and shrinking.
Bob Sanders is offline   Reply With Quote
Old 01-21-2015, 05:05 AM   #6
cia2a's Avatar
Rewards Points: 30
They are wood studs, this I know for sure
Sand down edges of drywall patch panel for tape? patchtaper Drywall & Plaster 2 12-15-2012 09:53 PM
Now the fun part! Crown molding on cabinets round II petros151 Carpentry 21 01-19-2012 02:44 PM
Tiling floor - corner edges ? campbell804 Flooring 2 02-08-2010 11:39 PM
Bedroom ceiling corner water stain timcsi General DIY Discussions 3 11-10-2009 04:07 PM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 12:35 PM
