Replacing Top Of Stair Railing With Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-10-2018, 02:40 PM   #1
Rewards Points: 22
Replacing Top of Stair Railing with Wall
So I'm looking to convert this area into a full blown kids playroom as its more functional for them anyways with the walls and ceiling. I'm wondering if I'm going to need to run some posts up to the ceiling to secure everything firmly, and how many. I plan on using a method like this
to secure the ends but am unsure if it will be enough, or maybe to much pressure on the joists if the kids get to knocking around and running into it. Any ideas?
Thanks.
SesameChicken is offline   Reply With Quote
Old 01-10-2018, 02:42 PM   #2
Rewards Points: 22
Re: Replacing Top of Stair Railing with Wall
Sorry here is a photo of the area.
Old 01-10-2018, 02:52 PM   #3
retired framer
Rewards Points: 18,776
Are not talking about a wall to the ceiling? Or are you just looking at replacing the spindles?
Old 01-10-2018, 02:59 PM   #4
Rewards Points: 22
Sorry about that, that's all pretty conflicting..
Looking at putting up a half.
Old 01-10-2018, 03:00 PM   #5
Rewards Points: 22
Same height as the spindles, they are nothing but a hazard at this point and need replaced.
Old 01-10-2018, 03:28 PM   #6
retired framer
If your posts are solid they should be attached to the joists below, then I would just incorporate them into the new wall. If not then the best would be a post on each side of the top of the stairs, the rest would be fine once they are sheeted with drywall.
Old 01-11-2018, 10:30 AM   #7
Rewards Points: 22
So your saying as long as I secure the two posts at the top of the stairs to some blocking between the floor joists below it will all be secure, so that would mean that I do not need to secure any posts to the rafters above?
Old 01-11-2018, 12:58 PM   #8
retired framer
If those two posts are solid leave them there and build the wall with them at or inside the end.
If they are solid they are built into the framing below. If they are not changing the framing from below would be tricky then I would go to the ceiling with those two posts
Old 01-12-2018, 01:58 AM   #9
Rewards Points: 6
Following are the tips-
1.Measure and Mark Important Locations
2.Mount the Brackets and Clamp the Rail
3.Cut the Rail Ends
4.Attach Returns and Rail
NitinKumud is offline   Reply With Quote
Old 01-12-2018, 06:44 AM   #10
Guapo
Rewards Points: 11,950
Replace the spindles with balusters 4" on center & it will be safe.
Guap0_ is offline   Reply With Quote
Old 01-12-2018, 07:51 AM   #11
Rewards Points: 898
screw drywall directly to newel posts. Assuming everything is solid as Neal suggested.
BIG Johnson is offline   Reply With Quote
Old 01-12-2018, 08:09 AM   #12
Guapo
Will building walls around the stairs do anything to the air flow in relation to temperature?
replacing bath wall heater with exterior outlet grjr Electrical 19 11-26-2014 11:15 PM
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Replacing garage door with wall containing window and/or door diyer101 Remodeling 9 11-23-2012 07:47 PM
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 07:00 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
