Replacing Paneling Withdrywall. - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-12-2017, 04:59 PM   #1
Rewards Points: 20
Replacing paneling withdrywall.
Hi! Remodeling my living room, ripped out old paneling to install drywall. The fireplace brick hearth extends flush to the adjacent wall and was installed AFTER the paneling. So I have a section of paneling trapped between hearth and studs. Hearth is 14" high by 16". How should I install drywall over this? How would I finish the drywall to hearth joint? The bricks are rough used bricks. Thanks!
Rick63 is offline   Reply With Quote
Old 08-12-2017, 06:37 PM   #2
Rewards Points: 20
Re: Replacing paneling withdrywall.
I think I've got it figured out. I'll dig out the old mortar and make a smooth line with fresh mortar, then cut the drywall to fit. Is there a way to remove your own post?
Old 08-13-2017, 11:45 PM   #3
retired framer
Rewards Points: 18,742
Or make the slot bigger with a grinder and diamond blade so drywall will fit behind.
Nealtw is offline   Reply With Quote
Tags
drywall to brick
Flood repair - wood paneling. MKMaster Building & Construction 4 07-06-2016 02:58 PM
Replacing wood paneling with drywall dwb1133 Drywall & Plaster 4 05-23-2016 06:44 AM
Pull the paneling?. Double S General DIY Discussions 4 08-25-2015 09:34 PM
Prepping wood paneling for painting... recommendations? roasted Painting 17 07-29-2013 10:47 AM
replacing paneling with drywall in a trailer? reesie1 Drywall & Plaster 2 04-30-2013 10:05 AM
