Replacing Door That Is Stucco'd In - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-27-2015, 03:47 PM   #1
Rewards Points: 310
Replacing Door that is stucco'd in
I have a 30" garage door that is stucco'd into the wall. Its old and I really want to replace it. Im debating on spending the extra 60$ on a door. I thought brickmold was for stucco'ing around the door so the door is flush with the stucco and the brickmold is basically flush with the wall. Or is the brickmold just basically a pre-installed door trim?
Any tips or links to videos of removing and installing doors that are stucco'd in without re-stucco'ing it?
bhollehday is offline   Reply With Quote
Old 08-27-2015, 06:36 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,496
Do you have brick mold on the jamb now? If so just cut the nails holding the brick mold to the jamb carefully so you don't mess up the stucco and put a new door with jamb in and screw or using a nail gun, nail the door back in place. Don't use hand nails, there is a real good chance you will mess the stucco up.
It is not an easy job but it can be done.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
replacing slab, how to replace under stairs johnny331 Building & Construction 1 01-02-2009 07:57 PM
Replacing large retaining wall notfromaroundhere Landscaping & Lawn Care 6 12-17-2008 12:30 AM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 07:27 AM
Replacing a bathroom fan RickT General DIY Discussions 2 10-28-2008 09:49 AM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 06:31 AM
