Replacing Basement Drop Ceiling W/Drywall - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-15-2012, 02:47 PM   #16
Originally Posted by sadic1 View Post
I'd be curious about that, too. I actually like the idea of building a box beam grid and throwing 4 x 4 sheets of drywall up there as "tiles". That would mitigate the problems of dealing with mechanicals because if you needed to get to something you could lift up one drywall square, and if something leaked onto it, you could replace 1 drywall square with no joint compound or finishing needed. I am guessing 4 x 4 spans of drywall might sag, though? How about 3 x 3 I wonder?
you and me both.
Hardway is offline   Reply With Quote
Old 03-15-2012, 08:37 PM   #17
I am using a 2x2 recessed panel and I think it looks good with recessed lights
and blends in well. Not too complicated and easy to work with for access above. A 2x2 panel is easier to replace than a 4x4 or something like it, IMO. Also easier to store if you decide to save some panels for the future.
pesos is offline   Reply With Quote
Old 03-18-2012, 10:23 AM   #18
Drywall grid system
Originally Posted by Hardway View Post
There is such a thing as a drywall grid? if so any info would be welcome.
I found this source for a drywall grid system, although I've never used anything like this for an overhead drywall application. Maybe it will give you an option to consider for unusual reno situations.
Ron
http://www.armstrong.com/commceiling...icle63637.html
CARSMills is offline   Reply With Quote
Best way To frame basement ceiling under pipes rhk119 Remodeling 5 02-14-2012 05:22 PM
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 12:44 PM
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 09:12 PM
changing drop ceiling to normal ceiling acoustic_bum General DIY Discussions 7 01-16-2007 07:52 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
