Replace Vinyl Window Sash 055 735816 - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-04-2017, 07:56 AM   #1
Rewards Points: 2
replace vinyl window sash 055 735816
Does anyone know the manufacture of this vinyl window.. Need to order upper sash as it has a pellet hole in it. If can't find who built it can any one recommend alternative beside replacing entire window as it sits by another in kitchen dinning area.
serial # 055 735816 built 09/15/2006
paul revere is offline   Reply With Quote
Old 03-04-2017, 09:30 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,242
Re: replace vinyl window sash 055 735816
Post up a picture of the sticker.
There is usually other identifying information on the sticker to clue you in to the manufacturer.
Old 03-04-2017, 09:53 AM   #3
Rewards Points: 2,438
When I cracked the vinyl lining on anderson windows, they sent me a tube of repair compound which worked well. It also doesn't seem to change color or attract dirt. As far as I know, vinyl windows frame is heat fused and would be next to impossible to replace just one part. But if you must, vinyl windows are also about universal so another window may give the parts you need.
carpdad is offline   Reply With Quote
Old 03-04-2017, 12:11 PM   #4
Rewards Points: 112
What part has the hole in? The glass or the sash. If it is just the glass then any glass shop should be able to make up a new glass panel and install it in your sash.
paul100 is offline   Reply With Quote
Tags
vinyl window sash
Window screen for top sash Druidia Windows and Doors 13 09-14-2016 11:32 AM
Help: Aluminum window repair (Sash screw thread stripped) Khufudude Windows and Doors 6 11-13-2015 02:11 PM
Vinyl bay window glass replacement pointguard Windows and Doors 9 07-06-2015 03:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
