Repair Or Replace Bath Fan? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 08-22-2018, 10:22 AM   #16
Rewards Points: 94
Re: Repair or replace bath fan?
Thanks guys but it seems the problem I'm going to run into is the ceiling hole. A quick look a Amazon and Lowe's and the two I picked, 2.0 sones or less, take a 9x9.25 hole so I'll have to be sure the finish ring can cover the drywall and popcorn patch.
ChuckTin is offline   Reply With Quote
Old 08-22-2018, 12:05 PM   #17
Rewards Points: 528
Your new motor part number is 23405ser. Shop around as the price varies widely
BayouRunner is offline   Reply With Quote
Old 08-22-2018, 01:10 PM   #18
Rewards Points: 94
Got 2 Utilitech bath fans. Looks like the light and trim ring will cover any excess opening since I'm going from round to square (needs 9x9).
These are model 7105-05 with LED light strips 2.0 Sone 100 CFM
Old 08-29-2018, 06:15 AM   #19
Rewards Points: 94
Disappointed.
New fan has a gratey/raspy sound. Quiet but still there . I checked everything and the noise is the fan itself - I can feel the vibration on the end (bottom) of the fan shaft.
It's possible the housing in not sitting exactly level - I installed it resting on the drywall ceiling, just enough overlap at the corners.
Blast and damn.
Seek Advice - Recharge, Repair or Replace Fujitsu Minisplit SanDiegoCool HVAC 2 05-10-2018 07:56 AM
Replace carpet or repair? J89Mike Flooring 4 01-30-2018 07:20 PM
soft spot at cross gable on roof. Can i repair or do i have to replace? rbooe05 Roofing/Siding 7 10-31-2017 02:33 PM
Repair or just replace Didymus21 Drywall & Plaster 4 11-03-2012 08:23 PM
torch down roof repair or replace? ohmiahgod81 Roofing/Siding 2 09-23-2012 01:25 PM
