Repair Or Replace Bath Fan? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 08-19-2018, 02:00 PM   #1
Rewards Points: 94
Repair or replace bath fan?
This pix is our bath fan(s), 2. Hall bath screaches. Master bath starts SLO, gets hot to speed and screaches.
Obviously bearings are going. Has anybody tried relubing or replacing the bearing on these?
This question is probably a non-starter but thought I'd put it out and maybe learn something.
TIA, CVT
ChuckTin is online now   Reply With Quote
Old 08-19-2018, 03:39 PM   #2
retired framer
Rewards Points: 18,590
Re: Repair or replace bath fan?
Not familiar with the modal but some motors are replaceable.
Old 08-19-2018, 03:41 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,512
Most of those fans I have seen have bushings, not bearings. You can lube(oil) them. I have done it. Depending on how bad they are they may run for along time before needing oil again or they may run for a month.
CodeMatters likes this.
Old 08-19-2018, 04:05 PM   #4
Rewards Points: 528
If you can get a number off the motor good chance you can replace it. Fixture still looks great. Model number may help as well but a lot of the older fixtures they’re not legible
BayouRunner is online now   Reply With Quote
Old 08-19-2018, 06:08 PM   #5
Rewards Points: 94
Thanks! Worth a shot then.
As to model #, I haven't a clue. New old house to us and I need to find that out, for certain. Even Google's image search came up 0!
BayouRunner and Nealtw like this.
Old 08-19-2018, 06:59 PM   #6
Rewards Points: 1,036
+1 to what joed said, sleeve bearings can be lubed , what do you have to loose.
Canarywood1 is offline   Reply With Quote
Old 08-19-2018, 08:10 PM   #7
Super Moderator
joed's Avatar
Have also replaced motors on ones that lubing no longer worked.
Old 08-22-2018, 09:48 AM   #8
Rewards Points: 94
Ok so now I know it's a NuTone model 8662.
Old 08-22-2018, 09:49 AM   #9
Rewards Points: 94
The pieces look like this:
Old 08-22-2018, 09:49 AM   #10
Rewards Points: 94
This is the motor:
Old 08-22-2018, 09:51 AM   #11
Rewards Points: 94
Here's the motor and mount:
Old 08-22-2018, 09:55 AM   #12
Rewards Points: 94
So I tried spray injecting some silicon spray lube into the upper bearing that's inside the squirrel cage.
Not.
Now it sounds worse!
Funny that I could spin the squirrel cage by hand and it was smooth and quiet, relatively speaking.
Oh well. I did measure the ceiling hole, 11 1/4" in diameter.
Old 08-22-2018, 09:56 AM   #13
Rewards Points: 94
So it's off to the box store (I prefer Lowe's) for replacements.
Old 08-22-2018, 10:02 AM   #14
Rewards Points: 1,086
silicon spray lube is not oil. bearings need OIL! 0W-xx motor oil seems to work well for most small motors.
spinning by hand doesn't move the rotor like turning it on does - often there's shaft play that is taken up when the magnets are powered.
u3b3rg33k is offline   Reply With Quote
Old 08-22-2018, 10:13 AM   #15
Rewards Points: 528
If you decide to replace just the motor I’ll see if I can come up with something. I don’t think you can buy that motor from anytime any more. But pretty sure we’ve used a fasco replacement. Might be a few days before I get to shop
Seek Advice - Recharge, Repair or Replace Fujitsu Minisplit SanDiegoCool HVAC 2 05-10-2018 07:56 AM
Replace carpet or repair? J89Mike Flooring 4 01-30-2018 07:20 PM
soft spot at cross gable on roof. Can i repair or do i have to replace? rbooe05 Roofing/Siding 7 10-31-2017 02:33 PM
Repair or just replace Didymus21 Drywall & Plaster 4 11-03-2012 08:23 PM
torch down roof repair or replace? ohmiahgod81 Roofing/Siding 2 09-23-2012 01:25 PM
