Repair Ceiling After Removing Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-07-2014, 08:26 AM   #1
Repair ceiling after removing wall
Hello, I'm looking for a way to patch the ceiling after removing the wall partitions of a former closet. I am expanding the entire small bedroom into a walk in closet.
Of course, the original ceiling is popcorn and has been painted.
Is there a product to cover the entire ceiling rather than scraping or replacing with sheet rock?
I have only 90 inches in height so I would rather not use a suspended system.
Thank you!
karenfritzohare is offline   Reply With Quote
Old 01-07-2014, 02:11 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
knock down the high spots on the stucco ceiling then go right over top of it witih 1/4" drywall.. much faster than trying to scrape down the entire ceiling which will more than likely need to be skimmed anyway. we do it all the time with homes such as this
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (01-07-2014)
Old 01-07-2014, 02:55 PM   #3
Rewards Points: 118
Bingo. Just did that in my kitchen. While the ceiling is trashed, its a good time add any overhead lighting, etc.
chrisb75 is offline   Reply With Quote
Old 01-18-2014, 01:07 PM   #4
Professional
TotalHomeworx's Avatar
If you want to keep the look of popcorn then I would patch and respray just the area and paint the entire ceiling. You will have to scrape about a foot off on either side to patch in the new drywall and prime it. Use thumb tacks and hang plastic where the popcorn starts all around the patch to the floor. Rent a texture sprayer and give it a go. add more spray if its too thin or scrape it off right away if its too thick. Let it dry and paint.
If you want a flat or different texture then you will have to scrape it off/ sand/skin/sand/prime and paint or put up the 1/4" drywall and finish that.
TotalHomeworx is offline   Reply With Quote
Old 01-22-2014, 02:29 PM   #5
Thanks all.
All of these answers seem to be very labor intensive. I was hoping to find some sort of easy solution...life the old tin ceilings.
I may just frame this out in pine and paint it to match the other wood work.
Guess it may become a "design element"!!
Thanks again.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Removing a Load Bearing Wall iengrave Building & Construction 17 08-10-2012 04:55 PM
Removing curtain track in ceiling and repair elllie General DIY Discussions 3 04-25-2010 03:45 PM
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 03:37 AM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
