Removing Wallpaper Glue From Plaster - HELP - Old Home - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Gymschu
  • 1 Post By firehawkmph
Old 01-30-2017, 06:39 PM   #1
Rewards Points: 2
Question
Removing wallpaper glue from plaster - HELP - old home
I am remodeling a room in my house, built in 1941. Various renters have lived here since 1986, so the walls have been painted more times than I can count. I originally thought the walls that I am re-doing in my daughter's room would have to be totally re-drywalled and so I was just going to add, yet another, coat of paint until such a destructive renovation could be done. Upon closer investigation I realized the original walls, which are plaster, were covered with wallpaper. The paint jobs have all been OVER the wallpaper...so I figured scraping the walls would be more cost effective, albeit I am realizing now, incredibly time consuming.
I bought an LED heater to help get the paint to come off easier, but I am having a really hard time with the glue. Is there an effective way to remove the glue and get the plaster clean again that isn't so unbelievably laborious? HELP!
helenaclaire is offline   Reply With Quote
Old 01-30-2017, 07:57 PM   #2
Super Moderator
Gymschu's Avatar
Rewards Points: 6,750
Re: Removing wallpaper glue from plaster - HELP - old home
No easy way here. In the history of home improvement projects, removal of painted over wallpaper is definitely in the top 5. Adhesive just takes lots and lots of elbow grease and hot water, lots of it. Use a garden pump sprayer to wet the walls. Keep wetting it over and over and over. Use a wallpaper scraper with a thin, sharp blade or a 6 inch putty knife to scrape off the adhesive. Sometimes mixing in a little DIF wallpaper removal liquid with the hot water helps. Wetting and scraping, wetting and scraping. Just learn to be patient and let the hot water soften up the adhesive.
abrowning likes this.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 01-30-2017, 08:01 PM   #3
firehawkmph's Avatar
Rewards Points: 2,452
Wallpaper paste is water soluble. Wet it down with hot water and let it soak for about ten minutes. That should soften it up. Sponge should take it off with a little elbow grease. Scraper helps too, with a light touch. Once you get all the glue off, walls are going to need to be patched, sanded, and primed.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-30-2017, 10:22 PM   #4
Rewards Points: 44
As gymschu and firehawk said, patience and wetting are the keys. I've used DIF before and it works well. There's also something called a paper tiger which scores the surface of the wallpaper so the wetting agent that you are using can penetrate the paint covered paper and get to the glue easier.
Resist the temptation to force the scraper. That just leads to wall gouges. Use a broad stiff blades scraper because it's less likely to gouge.
abrowning is offline   Reply With Quote
Old 01-31-2017, 03:26 AM   #5
Wallpaper glue that old may not dissolve, esp if you see no open seams-meaning some kind of excellent glue. I've seen crystalized glue that didn't work with water, maybe steam. Wallpaper may also hide damaged plaster. If you see the paper seams, you can gouge the seam, 2 coats oil base prime, compound repair with mesh tape, prime the whole area, then paint. Unless you want to restore to original, you'd want to remove the plaster or live with it. The old paint has lead in it, which is fine unless you start scraping and sanding it. Your proposal is bound to burn out your enthusiasm.
carpdad is offline   Reply With Quote
Old 02-12-2017, 10:59 AM   #6
Rewards Points: 122
Because of the risk of wallpaper paste residue, consider painting the substrate (plaster) with Zinnser "Gardz" sealer, before applying any subsequent "normal" primer & topcoat.
Adam_Reith is offline   Reply With Quote
Tags
old house , plaster wall , plaster walls , wallpaper glue , wallpaper removal
wallpaper glue removal bubbler Painting 20 12-31-2014 05:36 AM
Wallpaper removal from plaster walls Chokingdogs Drywall & Plaster 4 08-07-2014 06:42 AM
Removing wallpaper glue cj133 General DIY Discussions 10 04-18-2014 12:58 AM
removing old wallpaper from drywall bonnieardoin Painting 7 02-14-2014 06:28 AM
How to tell if all wallpaper glue is removed? CameraGuy Painting 11 04-04-2010 06:31 PM
