Removing A Wall/Fixing Ceiling Crack - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-16-2017, 07:30 AM   #1
Rewards Points: 4
Removing a Wall/Fixing Ceiling Crack
Good morning,
I'm looking for some advice as my husband and I look to remodel our kitchen and dining room. The previous homeowners removed part of a wall. They left part of the wall (as seen in the picture). Would it be okay to remove that? Also, they removed another wall and it appears there is now a crack that they attempted to hide. The crack doesn't look good so I'm wondering how we should go about fixing it? Any help you can offer would be very beneficial. Thank you in advance.
Removing a Wall/Fixing Ceiling Crack-img_2082.jpg   Removing a Wall/Fixing Ceiling Crack-img_2087.jpg   Removing a Wall/Fixing Ceiling Crack-img_2083.jpg
newhomeowner17 is offline   Reply With Quote
Old 11-16-2017, 08:18 AM   #2
retired painter
Rewards Points: 1,404
Re: Removing a Wall/Fixing Ceiling Crack
It's hard to say whether or not the part that protrudes down from the ceiling is part of a header or not. Normally a header would come down further for that large of an opening but it could be embedded in the ceiling. What is above that wall? The quickest, easiest fix would be to just caulk the crack.
The correct way to repair the crack in the 2nd pic would be to remove any loose tape, tape the crack and feather out the repair with additional coats of joint compound. You'd then need to match the texture with a round brush. Again it might be simpler to just caulk the crack [wipe off any excess caulk] and paint.
mark sr is online now   Reply With Quote
Old 11-16-2017, 08:26 AM   #3
Rewards Points: 4
Thanks for your help. Is the crack part of a bigger structural problem? It appears they attempted to take down a wall and as a result, there is now a large crack. Is it safe to just caulk it or do I need to make sure there's not a deeper issue?
Old 11-16-2017, 01:08 PM   #4
retired framer
Rewards Points: 18,706
We need to know what is above this. A bearing wall is carrying weight from above and need special attention. If you have an attic up there a quick look would tell you whether you have trusses or rafters. If you have trusses and a fairly straight forward roof line there is a good chance there is not much to worry about,
Removing recessed light housing from mirrored ceiling miamicuse Building & Construction 15 09-12-2016 03:09 AM
Hairline crack in 1950 plaster ceiling comes back nowwhatnapster Drywall & Plaster 8 08-11-2013 10:47 PM
Recurring ceiling crack - Drywall Expansion Joint? kuj0317 Drywall & Plaster 5 11-25-2012 11:27 PM
How to fix crack in butt joint on ceiling kurtinthebox Drywall & Plaster 3 07-16-2011 10:37 PM
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 08:32 AM
