Removing Shower Sliding Door Frame - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-14-2016, 12:33 PM   #1
Rewards Points: 119
Hi all,
I'm having the most difficulties removing a sliding door frame from the tile wall. I've scored the sides but can't easily remove the frame from the wall. The adhesive or silicon is like cement or something. I have several multi-tools with a scraper and a wood cutter. I'm also using GOO OFF adhesive remover. I maybe get like an inch done in like 20 minutes. It's just too slow and i'm concerned of breaking the tiles if I use to much force prying it out. There's already some cracks.
Any advice?
suncowiam is offline   Reply With Quote
Old 11-14-2016, 02:22 PM   #2
ZTMAN's Avatar
Rewards Points: 278
Re: Removing Shower Sliding Door Frame
Silly question, did you remove the screws holding the frame in place?
ZTMAN is offline   Reply With Quote
Old 11-14-2016, 02:23 PM   #3
Rewards Points: 119
Yes, yes I did.
Old 11-14-2016, 02:45 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,242
Get a thin section of wire and loop it around something hard on both sides. You can drag it behind the frame and cut the sealant/glue loose.
Old 11-14-2016, 03:47 PM   #5
Rewards Points: 119
Will try. Thanks!
Old 11-14-2016, 04:30 PM   #6
JUSTA MEMBER
Rewards Points: 3,574
Make that wire ridged, like an old guitar string.
Remember to tie it to strong handles, 1 inch dowels about 6 inches long work great.
The handles are for you to keep your fingers.
These garrotes are deadly.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
suncowiam (11-14-2016)
Old 11-16-2016, 03:29 PM   #7
Rewards Points: 119
I tried the wires. It didn't work either. Wires kept on breaking.
I just said screw it and broke what ever tiles I had to break to remove them.
Luckily the tiles were small 4x4 tiles so I don't have too much to replace.
Removing shower floor thinset beh162 Flooring 11 12-18-2016 12:20 PM
Help with removing Moen shower cartridge NABRIL Plumbing 14 04-18-2016 02:16 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
removing frame to sliding glass door luo2000 General DIY Discussions 1 04-09-2006 08:00 PM
