Removing Shower Pan - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-04-2019, 10:43 AM   #1
Rewards Points: 2
Removing Shower Pan
I’m wondering if I could get some input on this. I am removing this pan but what appears to be the rubber flange that I need to drill through in order to remove the pan looks like it’s metal.
I attached a couple pics. The first is when it was originally caulked and then after removing the caulk. The last is it zoomed in.
https://imgur.com/a/BtwWdTt
https://imgur.com/a/oYAdL7X
https://imgur.com/a/ZXBJeZ5
I’m afraid to drill through this just in case this is the incorrect way of removing this pan but I can’t see any other way. Bathroom is down to the studs now. Thanks!
Molski is offline   Reply With Quote
Old 02-04-2019, 05:19 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,666
Re: Removing Shower Pan
This appears to be a TOILET flange not a shower flange. Are you aware of that? Why are you needing to remove it?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Removing tile while NOT damaging the shower waterproofing jaketrades Plumbing 16 10-30-2017 07:47 AM
Shower Head (over head) dripping while using Hand Held Shower Head HTFreak Plumbing 14 09-29-2015 03:46 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Removing an old shower pan kvn Kitchen & Bath Remodeling 3 10-24-2010 08:23 PM
Removing solid shower base with marble chips WoozyChain Plumbing 2 08-15-2009 07:10 AM
