Removing Paper Off Base Floor - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-28-2014, 05:17 PM   #1
Location: I live in Mims, Fl. where you can feel the launch from the cape.
Removing paper off base floor
I have removed 3 layers, 1 tile, 2 linoleum, off the floor to find the base floor in my trailer. there is a heavy paper, I'm assuming it's a pad of some sort. This is a 1972 trailer. Anyone have any ideas on how to get this off the wood? I'm tired of using a paint scraper. Wetting and scraping doesn't work, either. HELP!!!!!!!
ande1 is offline   Reply With Quote
Old 07-28-2014, 05:25 PM   #2
Retired Moderator
Rewards Points: 7,174
That might not come off--what are you going to put down as your new finished floor?
Old 08-05-2014, 10:08 AM   #3
I was given some 18" by 18" vinyl tiles, I've laid tile before, just have to remember how to cut them. Most of the backing came off. Took 3 days and lots of elbow grease.
Old 08-05-2014, 05:04 PM   #4
Rewards Points: 17,884
1972 tells me most likely it's particle board flooring.
About useless for anything. Gets wet once and it turns to oatmeal.
Really needs to go for any chance of anything else working out long term.
Sure there not asbestos tiles?
May be the reason someone gave them to you.
What room is this?
A kitchen or bathroom should be done in sheet linoleum, not tiles.
Bridging--bouncy vibrating floor meature Building & Construction 15 02-05-2013 05:43 PM
Mid span bridging lylsutherland Building & Construction 2 10-29-2012 11:10 PM
tar/felt paper wet between floor & subfloor widowoman Flooring 1 09-03-2012 07:07 PM
Removing paint from edges of wood floor jfklein13 Painting 4 07-18-2012 07:53 PM
Removing tile from 2nd floor bedroom? Myst420 Tiling, ceramics, marble 3 08-24-2011 07:15 AM
