Removing Kitchen Pantry - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-05-2016, 07:44 PM   #1
Removing kitchen pantry
In the process of removing the built in pantry. When I opened the first wall I found there were vents in the floor and ceiling. The basement below is finished and the master is above. The pantry is located in the middle of the house. Not sure of the purpose of the vents but I would like to cover and install cabinets. Anyone know if there would be an issue to close the openings? The pantry is original to the house which was built in 2005
Removing kitchen pantry-1452044262398930618651_1452044272325.jpg   Removing kitchen pantry-1452044285740-1953283046_1452044295428.jpg   Removing kitchen pantry-1452044316247-2042687820_1452044325927.jpg
pgreaf is offline   Reply With Quote
Old 01-05-2016, 09:26 PM   #2
firehawkmph's Avatar
Rewards Points: 2,456
Looks like a cold air return. Still need that. Might be able to relocate to the attached wall. You'll have to see where it goes above and below.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-06-2016, 04:32 AM   #3
Rewards Points: 107
Yup cold air return to the upstairs. . Remove this and you will change your upstairs heat distribution. So it needs to be re-routed .
Plans don't remove my kitchen pantry, I couldn't live with out it 😏.
jimn01 is offline   Reply With Quote
Old 01-06-2016, 05:50 AM   #4
Thanks. I checked out upstairs and it is the return for the master. This wall stays. I don't want to go to the hassle of relocating. I'm replacing the ugly pantry with a cabinet with pull out shelves and a desk area.
Removing paint on kitchen cabinets to restore wood surface metriccar Remodeling 1 04-29-2015 06:29 AM
Kitchen Idea for old pantry. DTZee Remodeling 3 02-04-2015 06:55 AM
Removing Kitchen Stud Wall Below Scissor Truss smacman7 Building & Construction 3 12-12-2012 11:57 AM
Removing kitchen ceramic tile floor skullface Flooring 3 06-01-2009 09:55 PM
Worth removing the cabinets before painting my kitchen? J187 Painting 7 10-08-2006 08:02 PM
