Removing Flooring - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-24-2015, 04:25 PM   #1
Rewards Points: 2
Removing flooring
What would be the best way to remove vinyl flooring?
Realjomo is offline   Reply With Quote
Old 10-24-2015, 04:30 PM   #2
JUSTA MEMBER
Rewards Points: 3,590
How is it adhered?
A spread glue, peel and stick, or other way.
Try a commercial heat gun to loosen the adhesive.
Then a WIDE putty knife to scrape it.
ED
de-nagorg is online now   Reply With Quote
Old 11-04-2015, 09:03 PM   #3
Rewards Points: 254
It is most commonly adhered with a type of carpet glue or something of similar substance. I purchased a floor scraper with a long handle from Lowe's for about $15. Tool worked great and is rated for carpet, linoleum, and even breaking up tile. Look into something like this and some type of solvent to remove the excess adhesive. (It's not imperitive you remove every last atom of glue..as long as it's smooth and flat) Consider sanding as well, I would not point a commercial heat gun at my floor unless you're very careful with it. It's easy to start a fire with those on high power if you're inexperienced.
Cheers
mbrando1994 is offline   Reply With Quote
Old 11-18-2015, 11:22 PM   #4
To get rid of the glue that had been securing the vinyl to the sub floor is little tough. Use a utility knife to cut the vinyl flooring into 12-inch strips and use a scraper tool or a kitchen spatula to get the strip loose. You can also use a hammer-and-chisel combination to chip at the hardened adhesive.
EMampos is offline   Reply With Quote
Old 11-19-2015, 12:57 AM   #5
Scrapper and a knife are the correct materials. But I recommend you not to go on yourself if you are not perfect on the work. Do not hesitate to contact a professional service.
christopherjhar is offline   Reply With Quote
Old 11-19-2015, 08:08 AM   #6
Rewards Points: 17,890
What's going down for new flooring?
Old 11-19-2015, 09:35 AM   #7
Super Moderator
Gymschu's Avatar
Rewards Points: 6,768
Huh? Christopherjhar sounds a lot like soperfectpaint.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 12-10-2015, 01:49 PM   #8
Tony_G's Avatar
Rewards Points: 48
They're usually very hard to remove, what subfloor you have also makes a big difference.
For a concrete slab I would just rent out a floor stripper, if you have a plywood subfloor then a combination of head gun & floor scraper would be your best bet, I hate vinyl flooring, especially removing it!
Tony_G is offline   Reply With Quote
Old 12-16-2015, 04:25 AM   #9
Scrappers will be the right choice for you.
dennishcoook is offline   Reply With Quote
Old 01-14-2016, 12:57 AM   #10
Rewards Points: 402
Before you start it, do check what your vinyl has glued to. In case, it is glued to an underlayment, ailed or stapled, you can proceed by taking out the underlayment. Just set your skil-saw to a depth which allows you to cut through the vinyl and the underlayment and then you can easily cut it into long strips. Once you are sure about them, start pulling them out. Make sure you use a cheap framing blade and an eye protection.
fortunerestore is offline   Reply With Quote
Old 02-03-2016, 02:43 AM   #11
Rewards Points: 6
Just try to use scrappers lol
Sam Kundilovsky is offline   Reply With Quote
Tags
flooring , vinyl
Old House Flooring Installation Advice rsvedin Flooring 2 03-15-2014 07:12 AM
help removing flooring patrickb Flooring 6 01-14-2014 05:28 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
