Remove Medicine Cabinets - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-02-2016, 09:15 PM   #1
Rewards Points: 8
Remove Medicine cabinets
Have 3 medicine cabinets set flush mounted to wall and apparently glued together and to the wall. They are the kind that when you open the 3 mirrored doors you have a surround view of your head. Have removed mirrored doors and all screws from dry wall. The cabinets will not budge. Have no idea why they are still on the wall. Cannot remove them either individually or all together. Need Help!!!
LHank is offline   Reply With Quote
Old 07-02-2016, 10:42 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Remove Medicine cabinets
Might need to open up the drywall to remove the screws holding them to the studs.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 07-02-2016, 11:01 PM   #3
Rewards Points: 2,458
Or cut the backing with oscillating saw. Probably they were installed without knowing how to anchor them, so just glue them and screws into the drywall. There is no good way to save the cabinets nor the wall. If the mirrors are in good condition, I'd try to save the cabinet or the frames. Drywall is cheaper.
carpdad is offline   Reply With Quote
Old 07-03-2016, 12:59 PM   #4
Rewards Points: 8
Thanks to both of you. I concluded probably needed to destroy/cut away cabinets.
jlhaslip, not sure what you mean 'open up the drywall to remove the screws'. I have already removed visible screws in cabinet backing. Are there others? If so, how would I open up the drywall? Visible screws were in studs.
Old 07-04-2016, 05:29 PM   #5
Rewards Points: 8
SUCCESS! Used a pry bar on one end to loosen. a few minutes later while deciding where to pry next, cabinet set came tumbling down (jumped out of way!). No glue, apparently just 40 years of old paint holding it up. Thought I'd let you know. FYI guess one needs to be prepared for this 3 piece cabinet set to come down when last screw is taken out--50 lbs+ of heavy particle board. Really need two people.
Old 07-04-2016, 08:03 PM   #6
jlhaslip's Avatar
Rewards Points: 708
Glad for your success.
On a reno, I have run into medicine chests that were screwed behind the drywall. Really old reno's.
Old 07-05-2016, 09:27 PM   #7
Rewards Points: 8
Thanks, I was fortunate there were no screws behind the drywall. Actually, to my surprise, I have minimal damage to drywall. Working on removing old vanity, faucets, and top now--ugly plumbing, if original is 30 years old.
Laminate flooring, removing an (unexpected) subfloor, and cabinets. What do I do? siggyfreud Flooring 7 06-21-2016 08:00 PM
Remove soffits above cabinets and one of the boards is cut...need fix RyanD Building & Construction 4 10-26-2014 03:21 PM
Over the range microwave and offsetting 12 deep wall cabinets samotlietuvis Remodeling 4 09-24-2011 01:43 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Help! Can't remove old hinges hardware from kitchen cabinets. sabrosonics Remodeling 1 03-08-2008 02:29 PM
