Remove Basement Access 1 Of 2 - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-13-2015, 08:21 PM   #1
randlefactor's Avatar
Rewards Points: 39
Remove basement access 1 of 2
I'm starting to plan a kitchen remodel and one of my basement accesses is right under where I want to put full width countertops and base cabinets. It's a door in the floor with stairs beneath to an unfinished basement / crawl space 5 ft tall. My second access is a mini door (5ft tall) on the exterior of the house.
Is there any rule or code that requires access from inside the house? can I remove the stair and replace the floor in this area?
randlefactor is offline   Reply With Quote
Old 03-13-2015, 09:22 PM   #2
concretemasonry's Avatar
Rewards Points: 2,716
That door in the floor is probably adequate for access according to your local code.
If that same "door-in-a-floor" was in a bedroom, it would obviously not qualify as a qualifying egress exit. - A 4 or 5 year old cannot the expected to raise a door in a bedroom for an exit and climb down a stair/ladder to go to basement where there might not even be able to get out. - It all depends on the intended use of the door for code compliance purposes and could not be acceptable as an egress opening from a room.
Just a hint -
Dick
concretemasonry is offline   Reply With Quote
Old 03-14-2015, 08:15 AM   #3
Rewards Points: 6,889
I can't think of any but that may be different in your area. I also see no future potential for finishing that basement. Only possible reasons I can think to keep it are convenience and quick storm shelter entry point.
A quick call to building inspection in your area would answer that for you.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Getting heat to add on room with no basement access. jbockenfeld HVAC 19 01-23-2015 03:34 PM
Basement Access Door Replacement...Sealing Under Threshold. mgh-pa Windows and Doors 2 09-13-2014 09:54 PM
Prep to finish basement...Sub Panel? Thisgrub4u Electrical 14 01-06-2014 11:10 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Remove old glue from basement floor electricedge Flooring 2 11-29-2007 12:53 PM
