Remodeling: Enclosing A Covered Porch. - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-18-2015, 10:49 AM   #1
Rewards Points: 4
Remodeling: enclosing a covered porch.
I am starting a project to enclose our current covered porch. It is supported by block columns and is covered by a continuous shingle roof. I have been told that because it was built with a roof on it, the columns and floor joist, etc were structured to hold the weight of the roof already and I won't need to block to whole foundation by code. Is this correct? I was planning to block it just for insulation value, but need to know if it would have to be inspected... couldn't find the info in the endless pages of building codes for va... Help-anyone? Ideas on how to tie the new block into the old columns before parging it? We are in central VA and seem to be in earthquake central now!
kanga2007 is offline   Reply With Quote
Old 01-18-2015, 10:53 AM   #2
Rewards Points: 582
would need to see some pictures of what your plans are....yes you would need a permit and need to get it inspected..
Old 01-18-2015, 11:06 AM   #3
Rewards Points: 144
Is this on a slab or what?You mentioned Floor joist so it's confusing as to what type of structure you have.Pics would sure help.Block columns and floor joist don't usually go together.
Edit:Is this a wood floor supported by block piers?Not columns?
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
MTN REMODEL LLC (01-18-2015)
Old 01-18-2015, 12:25 PM   #4
Rewards Points: 4
sorry. yes block piers. decking boards on the diagonal across floor joists (I don't know what else to call them). Plate all around porch, just like house was done... we are just going to frame up the walls, push out the windows from old wall to new wall (at edge of porch)... got just about all the details worked out-just not the block work-can't seem to find the info to cover that!
Old 01-18-2015, 12:52 PM   #5
Rewards Points: 144
If your going to fill in the block under the porch and between the piers you will need a footing under it and some way to tie into the piers.
need to know if i have built a strong enough foundation and column's for my covered porch, there are 4. jackhill Building & Construction 6 01-24-2012 06:47 PM
Covered back porch question. Bugman1400 Carpentry 0 03-13-2011 07:17 PM
Covered Porch jsbeckton General DIY Discussions 4 03-06-2011 10:00 AM
Water problem in Florida -Will Covered Porch Help? Tally_Lassie Building & Construction 8 09-28-2008 07:01 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 06:54 AM
