Remodel Of Kitchen/living Room Split-level House To "open Concept" In Northeast - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-28-2016, 10:26 AM   #1
Rewards Points: 238
Question
Remodel of kitchen/living room split-level house to "open concept" in Northeast
Morning all... not really a DIY question, but I own a split-level and planning a somewhat "major" reno to open up the kitchen/dining/living room areas. This is a task that I cannot complete myself, but still want to be hands on. Being this my first home and remodel, any advice as far as looking for a contractor? Structural engineer or architect? and generally speaking advice on quotes/budget and staying away from the "scam" contractors....
If this question doesn't fall in the realm of this forum, I apologize...
Thanks~~~!!!
nutshellml is offline   Reply With Quote
Old 01-28-2016, 11:24 AM   #2
Retired Moderator
Rewards Points: 7,174
If you use an architect or designer, they will know of a contractor that delivers good value for money spent---
Some contractors are 'design build' outfits---they can do the engineering and construction.
Remember, with the 'design /build companies--they own the designs---so if you like their plans put not their price---you will not get the working drawings.
The local building department might be able to provide you with registered contractors. (but not a reccomendation)
lumber yards might offer a suggestion of a good contractor---
nutshellml (02-02-2016)
Old 01-28-2016, 02:28 PM   #3
Rewards Points: 6,889
Mike pretty much covered it. I do have one additional thought.
I think I would start by spending a few hundred dollars to get a structural engineer to look at the house and offer opinions. Written opinions and drawings add to the cost but you may need them if you proceed.
Every SL house I ever seen the center wall between the LR and kitchen is a load bearing wall for the ceiling joists and sometimes the roof. Removing it requires some engineering. Depending on what is below where the beam weight must transfer to a footer can greatly affect the cost and feasibility of the entire project.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
The Following 2 Users Say Thank You to Colbyt For This Useful Post:
joecaption (01-28-2016), nutshellml (02-02-2016)
Old 01-28-2016, 07:54 PM   #4
Rewards Points: 1,036
Home builders association is a good place to start.
https://www.nahb.org/en/consumers/ho...remodeler.aspx
Mingledtrash is offline   Reply With Quote
The Following User Says Thank You to Mingledtrash For This Useful Post:
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
My new project, 31 year old house... Axhammer General DIY Discussions 3 04-08-2009 08:46 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
