Relocating Light Switch - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-15-2017, 10:06 AM   #1
Rewards Points: 44
Relocating light switch
I demoed a non-load bearing wall that that had a lightswitch on it. I need to relocate it onto the exterior wall where it's coming out of. Looking at the attached pictures, I want to relocate it to the right between the studs. The stud the wire is coming out of is the last stud of the wall that was demoed, and it's part of an exterior wall. What are my options here? Can I simply cut out that stud, drill a hole through the stud next to it, and run the wire through there? The second picture shows how the point load is situated right above the studs in question, that's a roof rafter that's resting on it I believe.
Doelman is offline   Reply With Quote
Old 03-15-2017, 03:41 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 2,040
Re: Relocating light switch
Double post.
lenaitch is offline   Reply With Quote
Old 03-15-2017, 03:56 PM   #3
Rewards Points: 44
Indeed, I realized this was placed in the wrong subforum. Couldn't figure out how to delete it so if a mod could be so kind.
Troubleshoot a 4-way switch circuit: instructions for a 2-year-old pete0403 Electrical 21 09-26-2018 11:07 AM
Smart Light Switch Help wpascarelli Electrical 3 02-23-2017 09:35 PM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 09:37 PM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
