Relocate Let-In Brace For New Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-19-2015, 06:36 PM   #1
Rewards Points: 4
I'm in the beginning stages of moving my kitchen from one side of the room to the other. The plan was to cut in a new window over the new sink. I did some researching once I found this 1 x 4 diagonal bracing and found it to be the let-in brace to protect from wind and seismic activity. I've found a few posts saying it was OK to remove and some had alternatives.
Seeing as I live in the California bay area I definitely don't want to lessen my seismic bracing. None the less it's in my way. Is there any way I can remove this and install an alternative, out of the way of my new window? I'd even like to overkill it (without making electrical and plumbing a pain in the butt to install) seeing as I'm modifying original structure.
I've attached a pic with some info. This is an exterior wall with nothing but the black paper and stucco on it. The window is 30"wide x 36"tall and the wall is 11'3" x 94" from floor to ceiling. The window will be 5' to center off the backyard wall.
Thanks for any insight
ryaninsr101 is offline   Reply With Quote
Old 02-20-2015, 08:41 AM   #2
Rewards Points: 17,890
Raise the window, use a smaller window, or remove all the sheetrock and cover the wall with at least 3/4" plywood.
Old 02-20-2015, 10:37 AM   #3
Framing Contractor
Rewards Points: 50
Or you could redesign the kitchen, allowing you to move the window slightly left or right,
sixeightten is offline   Reply With Quote
Out of square window how best to install miamicuse Windows and Doors 5 04-19-2013 01:34 PM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 08:41 AM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
