Rehanging Kitchen Cabinets - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By cshuldberg
  • 1 Post By woodco
  • 1 Post By chandler48
Old 07-14-2017, 09:54 PM   #1
Rewards Points: 8
rehanging kitchen cabinets
I hired a contractor and they are having difficulty rehanging the kitchen cabinet doors. Some of them won't even close properly. They want to plane them to make them fit but I don't think that will work either.
I attached pictures.
I am desperate please help soonest.
rehanging kitchen cabinets-20170714_194541.jpg   rehanging kitchen cabinets-20170714_194550.jpg   rehanging kitchen cabinets-20170714_194556.jpg   rehanging kitchen cabinets-20170714_194602.jpg
cshuldberg is offline   Reply With Quote
Old 07-14-2017, 10:22 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,980
Re: rehanging kitchen cabinets
What's wrong with them.... except they are on their side..
MTN REMODEL LLC is offline   Reply With Quote
Old 07-14-2017, 10:30 PM   #3
Rewards Points: 8
Look at the way they close. I could only get the pics to load that way not sure why.
The doors are not hung right. hey overlap when they close and the top and bottom are not lined up right.
Old 07-14-2017, 10:51 PM   #4
Well... why don't you tell us some things.... like
Did the contractor mix up the doors relative to the cabinets????
Do the hinges have any adjustment... can't see in pic... I doubt they do
Were the cabinets removed... and releveled or "racked"
Why not fill and readjust the hinge placement.....
What explanation is the contractor giving for why they don't fit...
Are you sure a contractor is involved.....
Old 07-14-2017, 11:25 PM   #5
Rewards Points: 8
No they didn't keep track of each door in any way.
The hinges as far as I can tell are not adjustable.
They have refilled and still having same issue.
I don't know what you mean be releveled or racked.
And the contractors have no good explaination to why this is happening which is why I am here.
anything else you need to know to help.
MTN REMODEL LLC likes this.
Old 07-15-2017, 01:44 AM   #6
Rewards Points: 2,724
Theres your answer right there. The doors should have been put back the exact same way, in the same hinge holes, with the same hinge in the same spot. I not only mark each door, but each hinge as well, as they are either adjustable, or in your case sometimes need to be bent to make the door close flush
You need to totally redo the measurements for the hinges, fill the holes and hang them from scratch.
What were you doing with your cabinets? Why were the doors taken down?
woodco is offline   Reply With Quote
Old 07-15-2017, 02:45 AM   #7
Rewards Points: 8
We just purchased our house and we did a renovation including painting the kitchen and cabinets.
They have taken them down and wood puttied and rehung them and its still not right. Your looking at the second attempt at hanging them.
Old 07-15-2017, 05:43 AM   #8
Naildriver
chandler48's Avatar
Rewards Points: 3,498
These were handmade doors, meaning they were not made in a cabinet shop, so there will be differences, ever so slightly between door fit. I know of no way to do this, but take each door pair, set them in a hole and see if they fit. IF not, try another combination. Don't let them go drilling holes until they get that perfect fit between doors. It was a mistake not to denote which door went where, and the contractor is stuck with getting it right due to that error.
Gymschu likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
MTN REMODEL LLC (07-15-2017)
Old 07-15-2017, 05:49 AM   #9
retired painter
Rewards Points: 1,256
Part of prepping cabinets for paint is marking the doors so they go back to the same hole! I like to use a magic marker behind the hinge as it will generally bleed thru the paint. I suspect the fix is finding the right hole for each door - no easy task since they weren't marked.
mark sr is online now   Reply With Quote
Old 07-15-2017, 07:15 AM   #10
I dont get that. It sounds like they just no idea how to hang a cabinet door. Google it.
Old 07-15-2017, 08:27 AM   #11
CHANDLER ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^100%
Or, depending on how "drilled and screwed" your cabinets are now, you may want to try and find new hinge hardware that1) may have adjustment to them, 2)and will cover "drill and screw holes,3) and may not be bent.... basically start anew.
But, your contractor may not (likely not) be the one to do it.... While he is responsible for it, better make sure he knows what he's doing if he goes to do it.
Good luck.... Thanks for the previous answers... situation makes some sense now.
(Re-leveled or racked refers to when cabinets are taken down and reset... they can be leveled different, or if inexpensive built cabinets, they can be knocked/anchored "out of square" or racked.)
Old 07-16-2017, 08:49 AM   #12
Rewards Points: 62
You need to make sure the cases are level and plumb.
You will need to remove all the doors and start over. Make sure the doors are flat, I'm betting they aren't any more. They should have kept track of the doors, shame on them.
rockmup is offline   Reply With Quote
Old 07-16-2017, 10:43 AM   #13
Oso954's Avatar
Rewards Points: 1,756
I'm not sure that this contractor can do it right.
He should have known about keeping track of the doors.
In pic #1, the left hand (top?) screw appears to have missed the original hole entirely.
Oso954 is online now   Reply With Quote
Best paint for kitchen cabinets? W1ldC4ts14 Painting 10 10-13-2014 01:53 PM
Antiquing kitchen cabinets Beeba Painting 1 09-17-2012 07:22 PM
ceiling/wall slanting over kitchen cabinets fdf Remodeling 8 02-26-2012 02:52 PM
Are Kitchen Cabinets Secure richard7994 General DIY Discussions 6 11-06-2011 06:21 PM
Upper Kitchen Cabinets latemoy Carpentry 3 09-13-2011 06:31 AM
