Reframing Attic Ceiling - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 02-11-2019, 06:10 PM   #16
Rewards Points: 86
Re: reframing attic ceiling
Originally Posted by Nealtw View Post
Nails are fine.
Thanks! all done with collar ties!
I have a different question, I was reading about knee walls and different methods of framing and was wondering is there a preferred method? First method I'm considering is without a top plate and studs are nailed right to the rafter or with a top plate and studs are toe nailed to the top plate.
Also, I read somewhere that if I attache the wall to the rafter it immediately becomes a load bearing wall and snow loads and that sort of thing has to be taken into account? is that true?
ipokrov is offline   Reply With Quote
Old 02-11-2019, 07:52 PM   #17
Rewards Points: 5,818
Just to jump in, but I prefer a top plate on the knee wall to keep the line straight for the drywall. Even though it will be supporting the rafters it will not be a major load bearing wall. But leaving the top plate and placing the studs directly below each rafter will take care of any loading.
Neal can correct me as needed.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 02-11-2019, 08:36 PM   #18
Rewards Points: 86
Bud
Thanks, so without the plate I wont have to worry about the load?
Old 02-11-2019, 08:51 PM   #19
retired framer
Rewards Points: 18,792
Loading the floor would be the concern and should have been part of the calculation before a floor goes in. Usually we want the rafter beefed up for insulation, if that was extended full length it would almost double the loading the roof could take.
Don't forget the solid blocking between the floor joists just below that wall.
I Have never heard of a problem do to loading of the floor with a nee wall.
The Following User Says Thank You to Nealtw For This Useful Post:
ipokrov (02-11-2019)
Old 02-11-2019, 09:53 PM   #20
Rewards Points: 86
I did add blocking between each joist where I could reach it....
Old 02-11-2019, 09:59 PM   #21
retired framer
There should be no floor behind the nee wall so It all would be reachable.
Walking on joist in attic with drywall ceiling below panthar Drywall & Plaster 8 07-13-2016 02:38 AM
Ridge vent vs mushroom fan gtothek Roofing/Siding 8 03-30-2015 02:12 PM
How to level attic ceiling FileOpen Building & Construction 3 12-26-2014 10:04 PM
Snow in attic through mushroom vents,leaking into great room ceiling thom risley Roofing/Siding 17 02-03-2014 03:47 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
