Refinishing Shower Frame - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Bondo
Old 03-25-2018, 03:51 AM   #1
I have a 90’s Bath with shower stall. Frame is made of aluminum with polished brass finish. Looking to remove glass panels and paint/refinish frame. Looking for a antique black bronze finish. Any product or application recommendations? Refinish product must be rated for water contact.
keithwales is offline   Reply With Quote
Old 03-25-2018, 09:40 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,230
Re: Refinishing Shower Frame
Ayuh,.... The Problem yer gonna have is,....
The coatin' on it now is Anodized on,......
Unless you remove ALL of the anodizin', nothin' will stick to it,....
If ya grind off All of the anodizin, with a ssteel brush, yer left with bare aluminum,.....
To paint bare aluminum, there's a several step process, just to get to the Primer stage,.....
After the primer is on,...
Most any Quality paint will hold up, til ya scrub it with any sorta scrubbin' pad,....
So, in reality, replacin' the stall is the best way to change it's color,......
Bondo is online now   Reply With Quote
Old 03-25-2018, 09:57 AM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,020
I had the same problem getting rid of 70's gold in a home, BONDO is dead right.
If it is just the door, you can order a reframed door for several hundred dollars, but you have to shop around.
MTN REMODEL LLC is offline   Reply With Quote
Shower Head (over head) dripping while using Hand Held Shower Head HTFreak Plumbing 14 09-29-2015 03:46 PM
Frameless Shower Glass Panel shrinking from Frame JeffDIY Tiling, ceramics, marble 1 10-11-2012 04:36 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Shower Frame Seal Lightning General DIY Discussions 5 12-19-2010 03:12 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
