Reducing The Size Of The Opening In A Wall. - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-02-2016, 04:39 PM   #1
Rewards Points: 28
Reducing the size of the opening in a wall.
I have an opening in an wall that is over six feet. Unfortunately, the previous owners did not put in a header large enough for that size of opening.
I want to solve this by reducing the opening to 5'6". But, I don't want to put in 10 inches of jack studs.
Can I put in jack studs that aren't tied to the king studs or add spaces that are tied to the king and jack studs?
kbartels is offline   Reply With Quote
Old 03-02-2016, 05:16 PM   #2
Rewards Points: 17,890
What size header was used?
What's the loads above the opening?
Is it even a supporting wall?
Only need a bottom plate and 2, wall studs where you want the opening to end, there is no reason to fill the whole thing in.
Old 03-02-2016, 05:30 PM   #3
Rewards Points: 28
Load bearing
They used an nominal 9" header. Looks like a 2x12 ripped to be exactly 9". It is load bearing - basement wall of one story townhouse in Nebraska.
My reading of the code says even if it were a full 2x10, I could only span 5'9" (I have a 31' wide house).
Old 03-02-2016, 06:13 PM   #4
Got a picture?
Did they use 2, jack studs?
Is an inspector looking this over or is this something your coming up with?
If it was mine I'd just leave well enough alone.
I've installed many a 6' patio door with 2 X 10 headers and never had an issue.
A real 2 X 10 would have only been 1/2 wider.
Old 03-02-2016, 06:44 PM   #5
Rewards Points: 28
Yes, there will be an inspector as this is part of a finishing a major part of the basement - adding a bedroom, bathroom, and family room.
Originally, there was just a door and framing so there was a post of two 2x4's in the middle. And, only one jack stud.
So, I'm adding one jack stud to each side of the 6' opening.
Actually, a 5'6" opening is just fine - maybe better. After thinking about it some more it does seem (as per your suggestion) that I should be able to add a bottom plate and two 2x4's six or so inches inside one end.
If the inspector doesn't like it I'm sure he'll tell me how to modify it to meet the code.
Thank you for your thoughts and advise.
Tags
jack studs , spacers , support wall opening
Opening a load bearing wall bcemail Building & Construction 5 11-04-2015 01:29 PM
Load Bearing Wall? Master Brian Building & Construction 3 06-05-2015 10:32 PM
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Header size for ext. wall opening JulesB Carpentry 10 02-17-2011 07:52 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
