Reconstructing Driveway To Create Flat Area - Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 03-18-2019, 12:57 PM   #31
Hammered Thumb
Rewards Points: 260
Re: Reconstructing Driveway to Create Flat Area
Originally Posted by fusebox7 View Post
Does 4% sound like too much grade for a "flat" area? I've read that 2% is the minimum recommendation but is doubling that overdoing it?
The short answer is yes. The long answer I have two opinions.
The pro opinion sets grades given a puzzle with many variables which usually arrives at the minimal solution acceptable for the general public and governing authority (the wall height matters).
The personal opinion is derived from my own varied-slope driveway (used by lots of kids, car projects, carpentry, and such).
2%@20' at the garage - way too steep for kids play or my use
8%@20' entrance from street - max steep in winter to get up with summer tires
If you're spending upwards of $60K with the most important variable being an area for the kids, your personal enjoyment should dictate and go for as flat as you can without impeding water flow.
3onthetree is offline   Reply With Quote
Old 03-18-2019, 01:07 PM   #32
Rewards Points: 24
Interesting take. I didn't expect that response but if you make it extremely "flat" (less than 2% in your case) wouldn't you need additional drainage to avoid pooling of water?
fusebox7 is offline   Reply With Quote
Old 03-18-2019, 01:33 PM   #33
Hammered Thumb
Rewards Points: 260
1% flows
Old 03-18-2019, 01:36 PM   #34
retired framer
Rewards Points: 46
Have you found areas like the mall parking lots that are 2 or 4% so you know what that would look and feel like?
Do not use flat bottom gables with scissor trusses.
Old 03-18-2019, 02:33 PM   #35
Hammered Thumb
Rewards Points: 260
I know builders who work backwards from a 1% driveway to set the top of foundation - it usually winds up less than 1%. Water won't move much solids, but will flow slowly. I would say the closer to level the more important haunches and grade being below the edges becomes.
I'm not recommending less than 2%, just giving an opinion for you to weigh.
Old 03-18-2019, 02:40 PM   #36
Rewards Points: 24
The sidewalk on our lot varies from 2-4% and it seems reasonable but like you've said, if we're going through the trouble, might as well go flat as possible. Assuming there won't be drainage issues I would absolutely prefer "Basketball court flat".
Old 04-03-2019, 02:27 PM   #37
Rewards Points: 740
I would check to see if there is enough space to put in concrete steps that parallel the driveway to allow people to walk up them. Not unusual to see homes with steep driveways where the steps are in the very center going up to a home. A width of 24 inches is adequate and a tread depth of 11" or more with maximum riser height of 6 inches is very easy to navigate.
For the garage I would put down a length of rubber garage door weather strip as this will be high enough to prevent toys from rolling down to the driveway.
I have a similar driveway and even with a very rough surface finish it is still slippery and with my pickup truck I need to put it into 4WD to not spin the tires and leave rubber on the concrete.
I created a secondary parking area with the driveway as a Y to the right and this provided a flat space for parking outside of the garage. I added a pad on the other side of the garage as well for even more flat parking area.
Calson is offline   Reply With Quote
Old 04-23-2019, 12:57 AM   #38
nekraliuga's Avatar
Rewards Points: 6
Hi, I'm new here. :-) Saw the pics you've shared. What a quite big driveway project you've got. Good luck on that.
Cheers,
Nek from Las Vegas Garage Door Repair
nekraliuga is offline   Reply With Quote
Driveway drainage and pavers mark18 Landscaping & Lawn Care 1 10-23-2017 04:40 PM
I want to create a compost area. flashme18 Landscaping & Lawn Care 2 07-07-2008 10:59 AM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
Flat Roof Leak (used as patio above living area) brutter Roofing/Siding 4 04-13-2008 10:11 PM
