Recessed Toiled Installation - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By rubenhak
Old 02-04-2019, 11:37 PM   #1
Rewards Points: 32
Recessed Toiled installation
Hi everybody,
I'm thinking about installing a recessed toilet. Something like Toto Aquia:
I'm just not sure regarding rerouting the waist pipe. How complex would it be?
I'd appreciate some hints on this.
Thanks,
Ruben
rubenhak is offline   Reply With Quote
Old 02-05-2019, 04:48 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,352
Re: Recessed Toiled installation
If you already have an operational toilet, can you tell us why you want to change to a back discharge toilet? Do you have access to below the existing toilet?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 02-05-2019, 02:43 PM   #3
Rewards Points: 32
Well, want to remodel the bathroom, give it a modern look, save some space and overall make the bathroom cleaner.
Yes, I live in a single family house, subfloor, have access to crawlspace.
Old 02-20-2019, 07:52 AM   #4
Rewards Points: 12
Is your current toilet drain cast iron, or PVC?
huesmann is online now   Reply With Quote
Old 02-20-2019, 01:38 PM   #5
Rewards Points: 32
Honestly, I don't know. What difference would it make? Would it be nightmare to cut the cast iron?
Old 02-20-2019, 04:15 PM   #6
Naildriver
chandler48's Avatar
Without proper tools, think "Elm Street". You don't "cut" cast iron. You use a special chain tool that tightens around it and snaps it. It would help to know what you were up against before you dive in.
Larry......
Old 02-20-2019, 05:17 PM   #7
Mystriss's Avatar
Rewards Points: 7,354
Sounds pretty brave to me, I've had too many problems with toilet floats and gasket flaps to not have easy access to the tank...
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 02-20-2019, 06:06 PM   #8
Rewards Points: 32
We decided to do full bathroom remodel. Contractors should have the right tool for that.
chandler48 likes this.
Old 02-20-2019, 06:08 PM   #9
Rewards Points: 32
Could you tell bit more about that? Which carrier did you use?
Old 02-20-2019, 10:31 PM   #10
Rewards Points: 32
I have just bought the Toto Aquia with Geberit carrier tank. Geberit has a smaller footprint and seems like to be more robust then the toto one.
Old 02-21-2019, 06:01 AM   #11
Mystriss's Avatar
hmm it's just been over the past 30 years, different brands I'd imagine. We had to replace all three toilets in the house here, but they were probably from the 70s. Had to replace both of the tank guts in our old condo and the newer post 90s ones in our place in Arizona too.
Tags
recessed , reroute , toilet , waste
Recessed Lighting for High Pitched Sealing scootermcrad Electrical 3 01-23-2017 05:51 AM
Opening Ceiling Joist for Recessed Light DAKRO Building & Construction 14 01-01-2012 12:21 AM
Recessed lighting & ceiling fan installation advice SillySally Electrical 5 08-05-2009 10:07 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
